MSD Ignition #846535 11/11/07 12:50 AM
kneedragger Offline OP
Can I put an off-road MSD ignition box on my 86 trooper? If so where can I buy one from?
1986 Isuzu Trooper 2.3
2004 Suzuki GS500F
Re: MSD Ignition [Re: kneedragger] #846536 11/11/07 01:39 AM
N
NotSoSimple Offline
Do you have the 2.6?
I have an MSD on my '90 Trooper w/ a 2.6. I bought it off of a buddy. MSD 6A is the unit I am running. Only other thing you need is the correct Tach Adapter. I called MSD to get the correct part number for our trucks.
'90 Trooper - 2.6L 5-Speed - 1" BL - Custom Roof Rack+2x55watt ProComp - Herculined Interior - Pace Setter Header - Dynomax Super Turbo - K&N - ProComp ES3000 Shocks - Optima Red - MSD 6A - 31" Kumho Mudders - Black Rock Crawlers
Re: MSD Ignition [Re: NotSoSimple] #846537 11/11/07 01:41 AM
No I have the 2.3 4banger.
2004 Suzuki GS500F
Re: MSD Ignition [Re: kneedragger] #846538 11/14/07 12:42 AM
:bump: anyone? Im sure someone on this board has an MSD box on their 1st Gen trooper.
2004 Suzuki GS500F
Re: MSD Ignition [Re: kneedragger] #846539 11/14/07 12:43 AM
Richard Saylor Offline
Simple, yes. Indy 4x ... www.independent4x.com
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: MSD Ignition [Re: Richard Saylor] #846540 11/14/07 05:40 AM
MoogVO Offline
Why do you want an MSD ignition on your Trooper? Are you running nitrus or something else that you would need the ignition to compensate for by changing the timing more than the factory set up?
I am not flaming, just curious.
Tom Moog
1994 Trooper LS
Re: MSD Ignition [Re: MoogVO] #846541 11/14/07 08:18 PM
barak Offline
I found the MSD does make a tiny bit of difference to performance on my setup , and should help once i get around to putting in my supercharger.Even for a stock application , it will help , but don't expect a huge improvement thats super noticable.It just makes it run a little smoother , and I found it improved my idle just a tad.
Re: MSD Ignition [Re: barak] #846542 11/15/07 07:05 AM
I wasnt looking for a big bang for my buck, Including the MSD box with a better Cam, exhaust, and Carb, I should have a solid running engine the thing only has 1k on it.Oh and did I mention I may advance the timing if the can wont defeat the purpose.
2004 Suzuki GS500F
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6230 MB (Peak: 0.7056 MB) Data Comp: Off Server Time: 2026-05-29 22:44:15 UTC
