P0135 Fault Code 1998 Montero #846548 11/11/07 03:08 AM
RaideroftheLostArk Offline OP
I recently rented a Actron Scanner from Autozombie and pluged it into the OBDII. The code read "P0135-Heater sensor, bank 1, side 1). I think that has to do with the O2 sensor, but I know that there are about four of them on the car. Does anyone know exactly which one I should replace? I did a search and found a little information on the wire, but nothing that helped me specifically. All I found was that it might be the first sensor on the side with the cylinder one. Any ideas? Any thoughts would be greatly appreciated. Thanks! <img src="/forums/images/graemlins/scared.gif" alt="" />
1991 Montero 3.0 V6 LSD, 31x10.50 BFG All Terrains
Re: P0135 Fault Code 1998 Montero [Re: RaideroftheLostArk] #846549 11/11/07 04:24 AM
52degrees Offline
Pre-catalyst, Bank 1.
This means that it's on the side with cylinder #1, in front of the cat converter. I'd use a test light with the key on to confirm that the heater circuit is complete and getting power, and if it is, replace the O2 sensor.
While you're at it, replace the other 3. They won't be far behind...
KG6VNX
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.5889 MB (Peak: 0.6375 MB) Data Comp: Off Server Time: 2026-11-18 03:35:30 UTC
