Wicked shimmy under accelerartion #846647 11/12/07 04:01 AM
cokeslingin Offline OP
Have an 80 yota. Driveline seems to be fine. Could the Birfields be messed up and causing the vibrations?? The oil seals are bad at the birfield. Sorry don't know what that part of the axle is called?? The lack of oil is a problem, this I know, and speeds up the process of breaking down the birfield. <img src="/forums/images/graemlins/scared.gif" alt="" />Looking for a few places to start looking for the problem.
Re: Wicked shimmy under accelerartion [Re: cokeslingin] #846648 11/12/07 04:13 AM
4Crawler Offline
Assuming you have the front axle hubs unlocked and are in 2WD (2H) the front end should not have any impact on any shimmy. Front driveshaft and axle shafts should not be turning under those conditions.
You should fix the leaking axle and knuckle seals, left too long and the gear oil leaking out of the axle into the knuckles will wash the grease out of the birfield and wheel bearings and they can start to wear faster than normal.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5873 MB (Peak: 0.6353 MB) Data Comp: Off Server Time: 2026-11-02 12:29:35 UTC
