spindle nut adjustment...phillips head? #846856 11/14/07 12:04 AM
TexJeff87 Offline OP
Guys, on my 99 2wd rodeo, the spindle nut on the front right needs to be tightened. When I pull off the wheel, and the cap, there are 3 phillips head screws holding the retaining washer on. Is there a secret to getting those out? The heads were already boogered up...the metal seems to be very soft.
TIA...
Jeff
If Mad Max had a 4runner...
Re: spindle nut adjustment...phillips head? [Re: TexJeff87] #846857 11/14/07 12:47 AM
Richard Saylor Offline
I've used a torx bit that would just barely fit down in there and hammer it in on the ones that were already boogered. Worked for me several times that way. The extra edges on the torx help it bite more so it's less likely to strip again. Then go to the dealer or lowes (where I found new ones) or maybe home depot and get you some new ones in stainless steel.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: spindle nut adjustment...phillips head? [Re: Richard Saylor] #846858 11/14/07 01:40 AM
JLEMOND Offline
WHILE YOU ARE THERE GETTING THE NEW SCREWS , GET YOURSELF A SMALL HAND HELD IMPACT SCREW DRIVER , AND THEY WILL COME RIGHT OUT , JERRY
Re: spindle nut adjustment...phillips head? [Re: JLEMOND] #846859 11/14/07 02:03 AM
lttlbddy Offline
x2 on the impact driver <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: spindle nut adjustment...phillips head? [Re: TexJeff87] #846860 11/14/07 02:21 AM
strawmyers Offline
Isuzu Moderator
Previous thread
Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sean Strawmyer
Re: spindle nut adjustment...phillips head? [Re: Richard Saylor] #846861 11/14/07 07:45 AM
trooperbc Offline
....and get you some new ones in stainless steel.
AAARRGGHHH...i've just spent this side of forever searching for an old post about iirc why it's best not to replace these screws with stainless steel ; that they were purposefully spec'ed for brass for brass's lube qualities (or something like that) and that the brittle stainless would tend to break more easily.
i remember it was a convincing thesis, but i'm a little vague now on the details
anybody else have an idea about why brass was spec'ed for these little buggers, and whether we should stick with that spec?
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: spindle nut adjustment...phillips head? [Re: trooperbc] #846862 11/14/07 12:04 PM
strawmyers Offline
Isuzu Moderator
I have been running stainless ones for probably 5-6 years now with no catastrophic failures... and no more stripped out heads either. <img src="/forums/images/graemlins/wink.gif" alt="" />
Sean Strawmyer
Re: spindle nut adjustment...phillips head? [Re: strawmyers] #846863 11/15/07 12:49 AM
trooperbc Offline
so any ideas why brass was spec'ed?
//bc
Re: spindle nut adjustment...phillips head? [Re: trooperbc] #846864 11/17/07 06:21 AM
88SuperTrooper Offline
Hmmm, My Guess is brass was cheaper? And was WAYY to soft for what we do with them, Stainless is a great, I have not had any more stripped heads.
Thats just my guess. I bet I am wrong
Robbie--
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: spindle nut adjustment...phillips head? [Re: 88SuperTrooper] #846865 11/17/07 06:59 PM
mlclark Offline
Isuzu Moderator
Actually, brass is perfect for the application. Those screws have absolutely no other job other than to keep the washer on the spindle nut. They do not need to be tightened very much to do that job. Brass is also sacrificial, it saves both the spindle nut and the washer from getting chewed up.
The problem is that people do crank down on them and/or use the wrong screwdriver and then there are problems. Replacements in stainless are fine, but there will be a bit of galvanic corrosion between the screw and the spindle nut. I would suggest some anti-seize or those too will have to be extracted at some point in the future.
Good Luck
Michael
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6415 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-06-21 01:44:48 UTC
