New Tundra rear axle #847514 11/18/07 03:33 AM
L
Locked_Solid_Toy Offline OP
I was looking under the bed of those new Tundra's and the rear axle looks exactly like an eight inch 3rd member and all, except it looked bigger. Are they bigge,r if so how much and how much stronger. Also what would it take to put one a mini.
1985 yota 22RJasper motor w/ cam,webber carb.Marlin histeer & 4"springs, AllPro jonny jointshackles. Bds yj springs upfront. Bilstein 5150's all around. 4.88 yukon gears,detroit locker and truetrac. Fj80 Master cylinder, 33" MTR's
Re: New Tundra rear axle [Re: Locked_Solid_Toy] #847515 11/18/07 04:14 AM
Adam F Offline
I was curious too. I don't think it looks like an 8" The pumpkin looked round to me. Looked more like a Ford 9" to me. And I would think it would take a few thousand dollars to buy one from the dealer, since it would be next to impossible to find one in a junkyard since nobody in their right mind would junk a new Tundra.
Here's a pic I stole from tundrasolutions...
http://www.tundrasolutions.com/forums/tundra/115922-diy-change-rear-differential-fluid-2007-a/
97 4R, stock, daily driver
Re: New Tundra rear axle [Re: Adam F] #847516 11/18/07 07:30 AM
G
Greg_Canada Offline
The V6 and i-Force 4.7 V8 Tundra models' rear differential uses a 9.5-inch ring gear, and the i-Force 5.7 models step up to a 10.5-inch ring gear -- one of the largest in the segment. All Tundra differentials are made using new machining technology: "face hob" gear cutting for ring and pinion gears yields stronger tooth form and a greater engagement area for increased torque capacity and reduced gear noise.
From Auto Channel
89 4Runner
Re: New Tundra rear axle [Re: Greg_Canada] #847517 11/18/07 04:36 PM
OOP'S Offline
There is a write up on them in the latest Petersens 4-Wheel & Off-Road magazine. Seems to be a pretty healthy rear end. They are built by the Hino truck division of Toyota. Not much aftermarket support yet but ARB is working on a locker.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: New Tundra rear axle [Re: OOP'S] #847518 11/18/07 10:40 PM
L
So once the after market develops some lockers and gears would it actually be resonable to instal one of these rearends instead of a Dana 44, or a 14 bolt say if you were trying to build a rock crawler with as much toyota parts as possible. or would it just be better and stronger to go with the other two axles.
Re: New Tundra rear axle [Re: Locked_Solid_Toy] #847519 11/19/07 02:31 AM
OOP'S Offline
According to the write up, it is comparable to the 14-bolt and Dana 60/70
Axle size is 1.47, 36 spline count
14-bolt axle size is 1.5; they do not give spline count
They do not give axle size for D-60/70 but some have a 35-spline count
The R & P is 10.5, which is comparable to the 14-bolt and the D-70.
Even though it is low pinion, the pinion is not as low as the 14-bolt or the Ford 9-inch.
The brakes are huge, close to a 14-inch rotor. One down side, only 5-lug and it is not a standard size, 5-on-150 MM (5.9 inch)
You know that in time there will be aftermarket support for this axle. Right now, it is only offered with two gear ratios, 4.10 and 4.30. I would expect to see other ratios aftermarket and aftermarket housing, like Diamond Axle housings.
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6145 MB (Peak: 0.7008 MB) Data Comp: Off Server Time: 2026-05-29 22:22:07 UTC
