Swapped 3.4 is flooding? #847530 11/18/07 02:13 PM
CAZ Offline OP
Toyota Moderator
All,
I developed a strange problem with my swapped 3.4 yesterday. It has been running like a top for 15k miles since I did the swap.
Yesterday I went out to start it, and it would not start. It turned over fine, and it sounded a few times like it may want to start, but did not.
It smelled like it was flooding!
After double checking a few things, I decided to unplug the fuel pump. I did this, and after a few seconds of cranking the truck started!
I plugged the fuel pump in again and the same thing happened. I had to unplug it again to get it to start.
Once I got it running with the fuel pump plugged in, I took it for a drive and it was fine.
I am at a loss on this one! Anyone have any ideas? Could it be a leaky injector or something?
Thanks,
CAZ
Re: Swapped 3.4 is flooding? [Re: CAZ] #847531 11/29/07 12:25 AM
Kutter Offline
I'm just guessing too. I would investigate for a leaking injector since it starts with the pump off like you described. Maybe try unplugging the injectors electrical connector one at a time then try to start each time to see if you can identify one that is causing the problem.
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4
1995 4Runner V6 Auto 2WD
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5853 MB (Peak: 0.6339 MB) Data Comp: Off Server Time: 2026-07-13 16:18:35 UTC
