Gen3 gears?!?
#847533
11/18/07 04:22 PM
Anyone have any info on gears for the Gen3 trucks?
5th gear is almost unusable after I added the 33's. <img src="/forums/images/graemlins/frown.gif" alt="" />
Sure would like to be able to change the axle ratios...
2003 Jeep Grand Cherokee 34K 6" Long arm lift Rock Sliders ARB Bumper(s) Mile Marker winch 285/75/16 Dueler AT's ARB air locker (front) Custom Roof Rack
Re: Gen3 gears?!?
[Re: Seif1]
#847534
11/18/07 06:54 PM
you can go to the dealer and buy 4.90's and they're cheap. the expensive part is having someone else install them, that's why o did my own.
Re: Gen3 gears?!?
[Re: TOASTY]
#847535
11/18/07 07:18 PM
You can find hole axle assembly off junk yard pretty cheap. Out of Gen 3 01-02 XLS they got 4.90. It's direct swap. Only problem is to find used one with Hybrid LSD like in your current rear axle. Those tend to be more expensive and rare than open diff.
92 SR, 285/75R16 Yoko MT ARB locker GAST compressor AirLift 1000 MM10500 Snorkel custom rear bumper 02 Montero LS died protecting the master 08 PowerWagon (stock!)
Re: Gen3 gears?!?
[Re: Alex Kogan]
#847536
11/19/07 05:03 AM
[quote]You can find hole axle assembly off junk yard pretty cheap. Out of Gen 3 01-02 XLS they got 4.90. It's direct swap. Only problem is to find used one with Hybrid LSD like in your current rear axle. Those tend to be more expensive and rare than open diff. [/quote
I have an '01 "Limited"....What ratio do I have now?
Re: Gen3 gears?!?
[Re: Seif1]
#847537
11/19/07 05:41 AM
You've got 4.3. I've got 4.9 on my Gen3. Running 33 don't feel much different except for dismal mileage. I only felt real strain towing my popup at high altitude, or going over 75 mph. <img src="/forums/images/graemlins/ignore.gif" alt="" /> 4.9 will make nice difference on and off-road especially considering low 1 gear you have. In 1 gear low you'll have reduction almost matching Gen 2 or 1 with AUS 2.85 gears)
Re: Gen3 gears?!?
[Re: Alex Kogan]
#847538
11/19/07 06:15 PM
Hi Alex, Out of curiosity did the five speed auto come with the 4.9 gears or was the change to the five speed when the 4.3 came in?
Re: Gen3 gears?!?
[Re: OldColt]
#847539
11/19/07 06:53 PM
They were parallel on 01-02 trucks: XLS came with 4 speed and 4.9 while Limited had 5 speed and 4.3. After switching to 3.8L in 2003 on XLS and Limited came with same 5 speed and 4.3
