Gen3 gears?!? #847533 11/18/07 04:22 PM
Seif1 Offline OP
Anyone have any info on gears for the Gen3 trucks?
5th gear is almost unusable after I added the 33's. <img src="/forums/images/graemlins/frown.gif" alt="" />
Sure would like to be able to change the axle ratios...
2003 Jeep Grand Cherokee
34K
6" Long arm lift
Rock Sliders
ARB Bumper(s)
Mile Marker winch
285/75/16 Dueler AT's
ARB air locker (front)
Custom Roof Rack
Re: Gen3 gears?!? [Re: Seif1] #847534 11/18/07 06:54 PM
you can go to the dealer and buy 4.90's and they're cheap. the expensive part is having someone else install them, that's why o did my own.
Re: Gen3 gears?!? [Re: TOASTY] #847535 11/18/07 07:18 PM
Alex Kogan Offline
You can find hole axle assembly off junk yard pretty cheap. Out of Gen 3 01-02 XLS they got 4.90. It's direct swap. Only problem is to find used one with Hybrid LSD like in your current rear axle. Those tend to be more expensive and rare than open diff.
08 PowerWagon (stock!)
Re: Gen3 gears?!? [Re: Alex Kogan] #847536 11/19/07 05:03 AM
Seif1 Offline OP
[quote]You can find hole axle assembly off junk yard pretty cheap. Out of Gen 3 01-02 XLS they got 4.90. It's direct swap. Only problem is to find used one with Hybrid LSD like in your current rear axle. Those tend to be more expensive and rare than open diff. [/quote
I have an '01 "Limited"....What ratio do I have now?
Re: Gen3 gears?!? [Re: Seif1] #847537 11/19/07 05:41 AM
Alex Kogan Offline
You've got 4.3. I've got 4.9 on my Gen3. Running 33 don't feel much different except for dismal mileage. I only felt real strain towing my popup at high altitude, or going over 75 mph. <img src="/forums/images/graemlins/ignore.gif" alt="" />
4.9 will make nice difference on and off-road especially considering low 1 gear you have. In 1 gear low you'll have reduction almost matching Gen 2 or 1 with AUS 2.85 gears)
Re: Gen3 gears?!? [Re: Alex Kogan] #847538 11/19/07 06:15 PM
Hi Alex,
Out of curiosity did the five speed auto come with the 4.9 gears or was the change to the five speed when the 4.3 came in?
Re: Gen3 gears?!? [Re: OldColt] #847539 11/19/07 06:53 PM
Alex Kogan Offline
They were parallel on 01-02 trucks: XLS came with 4 speed and 4.9 while Limited had 5 speed and 4.3. After switching to 3.8L in 2003 on XLS and Limited came with same 5 speed and 4.3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6185 MB (Peak: 0.6936 MB) Data Comp: Off Server Time: 2026-06-23 00:43:13 UTC
