Re: Power Steering Pump Going Bad (pics)? [Re: longhaul] #847684 11/29/07 05:11 PM
L
longhaul Offline OP
Thank you for the good info. Where does the sleeve go? Is the seal/sleeve combo something that will require removing the crank sprocket?
If I have to remove the crank sprocket do you recommend loctite for the TC cover bolts when I put everything back together? All of them or just some? Are there any bolts that require silicone to prevent leaks?
Leaks are a buzz kill.
Re: Power Steering Pump Going Bad (pics)? [Re: longhaul] #847685 11/29/07 11:23 PM
Staceman Offline
just pull off the bottom pulley, or, harmonic balancer as its called. Sleeve goes over its shaft. New seal drivin into the oil pump housing, and your done. Nothing more required than loosening your belts, walking off the harmonic balancer, installing sleeve, remove old seal, replace new seal, install harmonic balancer, tighten belts.
No need to go inside the timing cover at all.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.5941 MB (Peak: 0.6585 MB) Data Comp: Off Server Time: 2026-07-16 03:38:03 UTC
