Automatic Hubs #847854 11/19/07 09:00 PM
Tweeder Offline OP
How sturdy are the stock hubs on the front of the Troopers? I've seen several car domain pages where folks put manual hubs as replacements, and I was wondering if there was a reason why. Should this be something I should look into doing?
89 Trooper
Visit Southern 4x4
Re: Automatic Hubs [Re: Tweeder] #847855 11/19/07 09:25 PM
Craig Offline
The automatic locking hubs tend to develop problems over time--failing to lock or failing to unlock. Manual locking hubs eliminate those quirks and assure you that at least one front wheel (or both with a locking differential) is in engaged when in 4WD. They ensure positive control of an important function.
Buy a Trooper. You'll be glad you did.
Re: Automatic Hubs [Re: Craig] #847856 11/19/07 09:42 PM
litnin Offline
Also, you know for a fact they are locked when you turn the knob.
With automatic hubs, they have to move several inches before they lock or unlock.
If you get stuck and put it in 4wd, your automatic hubs may until you've dug yourself in to a rut with the rear wheels.
When manual hubs, as soon as you turn your knob, the hubs
are locked and the front wheels immediately have power to them.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Automatic Hubs [Re: litnin] #847857 11/19/07 11:03 PM
Tweeder Offline OP
Thanks guys. What would be some suggestions for good manual hubs for the Trooper?
89 Trooper
Visit Southern 4x4
Re: Automatic Hubs [Re: Tweeder] #847858 11/19/07 11:08 PM
jezeric Offline
Isuzu Moderator
Stock Aisins are almost universally considered the best option readily available. Any Trooper, Rodeo, or P'up after about '88 and before 2000 is generally a safe donor, or you can contact someone like Matt at Independent 4X (www.independent4x.com) and see what he has available.
James
Re: Automatic Hubs [Re: jezeric] #847859 11/19/07 11:48 PM
litnin Offline
James
+1
Re: Automatic Hubs [Re: jezeric] #847860 11/20/07 06:00 AM
Tweeder Offline OP
Thanks. I'm going to check out Independent4x.
89 Trooper
Visit Southern 4x4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6146 MB (Peak: 0.6889 MB) Data Comp: Off Server Time: 2026-06-17 06:22:00 UTC
