air/fuel ratio gage in my 22r carbed engine? #847931 11/20/07 08:04 AM
haulie Offline OP
I bought a 3 gage windshield pillar post for my '84 truck. Two of the gages will be the usual suspects, water temp and oil pressure.
I'm considering putting a fuel injection exhaust manifold with the stock screw in O2 sensor on the engine I'm building. The engine I've got is a "bowtie block", i.e., 85 and later. I'm looking at an autometer air/fuel narrow ratio gage. see here I'm thinking that it could be a useful tuning tool.
Anyone done this? Would it be useful, or just an instrument of self torture? <img src="/forums/images/graemlins/scared.gif" alt="" />
Any other ideas on what to fill the third hole with? Ammeter, oil temp, cylinder head temp?
Thanks
Re: air/fuel ratio gage in my 22r carbed engine? [Re: haulie] #847932 11/21/07 03:41 PM
fourwd1 Offline
Seems like a waste of $, there isn't a whole lot of tuning to be done with the carb. To me a ammeter or vacuum gauge would be more useful, and cheaper.
just my .02
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: air/fuel ratio gage in my 22r carbed engine? [Re: fourwd1] #847933 11/21/07 03:49 PM
dcg9381 Offline
I like 'em.
Just so you understand - a narrow band really has three positions: rich, stoich, and lean. That's all it's really going to tell you. Peak power is around 13.3-13.8 AFR, which is rich... I find them to be reasonably useful tools when tuning if you're not school.
22REturbo.net
1988 4Runner
Re: air/fuel ratio gage in my 22r carbed engine? [Re: dcg9381] #847934 11/21/07 04:07 PM
G
Greg_Canada Offline
A wideband o2 sensor would be nice but you probably dont want to spend that kind of money.
I'd install a vacuum gauge...
89 4Runner
Re: air/fuel ratio gage in my 22r carbed engine? [Re: Greg_Canada] #847935 11/21/07 04:50 PM
haulie Offline OP
Thanks for the replies. I'm not too familiar with the vacuum gage concept. What is telling me and why is it useful?
Re: air/fuel ratio gage in my 22r carbed engine? [Re: haulie] #847936 11/21/07 05:36 PM
G
Greg_Canada Offline
Here's a 4crawler link, get used to them (lol)
Gauge pod
89 4Runner
Re: air/fuel ratio gage in my 22r carbed engine? [Re: haulie] #847937 11/24/07 05:45 AM
4Crawler Offline
A quick web search will find lots of vacuum gauge information:
http://www.centuryperformance.com/vacuum.asp
Never had an A/F meter on a carbed engine but do have one on my 22RE. I find it rather handy for monitoring engine operation and finding optimal operating conditions. For example nice to find out if the ECU is running in open or closed loop mode in different gears up a grade.
I have had vacuum gauges on most every vehicle I have owned over the years. Good thing to check for a feeling of how hard the engine is working and if you have any extra power in reserve, like when pulling out to pass someone. If the gauge is down under 5" Hg, not much is going to happen when you mash the gas pedal down. The vacuum readings (and engine power) will vary with elevation and the gauge can help you see that power drop-off and you can adjust your driving accordingly.
Re: air/fuel ratio gage in my 22r carbed engine? [Re: Greg_Canada] #847938 11/26/07 09:06 AM
Snowtoy Offline
X2
The cheaper A/F gauge will only tell you if you are running rich or lean at any position, otherwise it will cycle between lean and rich in its normal operation. I imagine if the carb was running rich/lean at idle you could use the meter to tune the carb until the meter cycled between lean/rich.
I find mine usefull to keep from wasting fuel when taking off or climbing a hill and I don't need to have the throttle down, i.e., using just enough gas to accelerate w/o pegging the meter in the rich.
Re: air/fuel ratio gage in my 22r carbed engine? [Re: Snowtoy] #847939 11/29/07 05:31 AM
dcg9381 Offline
Just to note.. a "good" wideband will run you between $175-$200, you don't need a $350-$400 unit.
The LC-1 works great and can be hooked up to a narrowband gauge (programmable output) - the narrowband guage can then give you REAL air/fuel ratio.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6299 MB (Peak: 0.7340 MB) Data Comp: Off Server Time: 2026-06-10 07:17:28 UTC
