p/s pump and box
#848175
11/21/07 06:50 PM
I swapped my 2.6 for a 2.3 diesel in my 89 D50. The diesel came out of a 86 Ranger and had the p/s pump attached running a serpentine belt. I left the this setup on (can't get V pulleys for the engine) and made up some fittings to connect to the stock box. Worked for a few days.
The pump was making a slight buzzing sound, and then it blew the steering shaft input seal on the box. (Ranger puts out 1500 psi. Too much for Dodge box?) Does anyone know where I can get a new seal? Or possibly a new box? I can't get either locally.
I guess I also have to change the pump back to the stock Dodge, which looks like I have to fire up the lathe to swap pulleys (gas has V, need serp. and the pulleys dont interchange) or is there a pump off of some type of other vehicle w/serp pulley that will work?
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
Re: p/s pump and box
[Re: 89Diesel]
#848176
11/21/07 07:10 PM
Pretty interested to hear the verdict on this one.. I am also planning to use the Ranger pump and Mitsu box on my swap. I wouldn't think that the pressures are so different between the two systems that it would cause a seal to burst.....
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
[Re: 89Diesel]
#848177
11/21/07 11:29 PM
Most mitsubishi's & Chryslers have the same pump. Just go to the bone yard & find one that mates to the belts... \Ed
Yankneck = Yankee ingenuity with Redneck stupidity. "How can I break it better?" 89 Raider 3.0 w/ 31's for now
[Re: yankneck696]
#848178
11/22/07 03:00 AM
Powell already solved this one on the diesel board. He's swapping a 2.3 from a Ranger to an 87 swb monty and had a pulley cadcammed. Just read the post the other day.
[Re: fasteddy]
#848179
11/22/07 03:05 AM
The Mitsu Box gets really mad when you put a 4.3 Pump on it as well. At least it did in my case.
[Re: LandRaider]
#848180
11/22/07 11:20 AM
Has anyone thought about using an AGR pump and box?
[Re: 89Diesel]
#848181
11/22/07 12:04 PM
If you look at the Mitsus made in the 90s most all of them have serpentine belts. I would grab one from a V6 pickup or Montero as my first choice. Try to get one from a truck so it matches the flow specs of the steering box. Mitsubishi uses PS pumps that have a liner flow output, the American pumps are variable flow, more rpm more fluid. As others have found, they do not work.
[Re: 89Diesel]
#848182
11/23/07 05:01 AM
(Ranger puts out 1500 psi. Too much for Dodge box?) 1500 psi sounds REALLY high to me.... I don't know too much about PS systems, but from what i can tell by looking at the pump there is a spring that controls the output pressure and/or volume. Would changing the spring rate on this be an effective way to lower the output pressure? Just trying to see if I can work with what I have because I don't want to have ANOTHER pulley fabbed up don't really want to wait on a v6 pump that may not be what I need either. Thanks guys -Dylan
[Re: dylanb]
#848183
11/23/07 05:06 AM
1500 psi sounds REALLY high to me....I don't know too much about PS systems 1000-1500 psi is not uncommon.
[Re: OldColt]
#848184
11/23/07 05:08 AM
Mitsubishi uses PS pumps that have a liner flow output, the American pumps are variable flow, more rpm more fluid How is it regulated then? I thought it was a simple vane pump.
'06 Dakota QC 4.7 6sp 4x4 '88 Mighty Max '77 KZ1000 fun old bike
