ball joint spacers #848323 11/22/07 04:49 AM
A
ak92toyota Offline OP
i was just wondering if it is posible to run a 33-12.5 on a 15x8 rim with the 1.5 ball joint spacer? i have 32-11.5 on stock now with minimal rubbing thanks
Re: ball joint spacers [Re: ak92toyota] #848324 11/22/07 05:55 AM
P
PETE_YK Offline
I ran 33x12.5s on the 15x7 alloys on my 88 p/u with no lift and no rubbing once i took the sway bar out and still had room when flexing, although i think the 3rd gen trucks have a little less room.
My 2 cents.
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: ball joint spacers [Re: ak92toyota] #848325 11/24/07 04:39 AM
4Crawler Offline
A 33x10.50 should fit no problem on the stock rims, 33x12.50 might squeeze in there given a narrow wheel or close to stock backspacing:
- http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10
Likely will have to do a fair bit of trimming and/or add a small body lift if they rub.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5937 MB (Peak: 0.6464 MB) Data Comp: Off Server Time: 2026-06-17 10:37:48 UTC
