water leaking into 85 4runner
#848385
11/23/07 12:18 AM
I was fixing a small rust hole on the floorboard of my 4runner near the ecu and i noticed that the carpet was wet. I looked up to and noticed that water was coming in from the radio antenna grommet and another point above that but i could not see. I checked the drivers side of the truck and it seems like i have a leak there too. Any ideas? I think i remember reading that some seams under the cowl leak but im not sure. Any suggestions would be great thanks.
1985 4runner
Re: water leaking into 85 4runner
[Re: 4x4yotaman]
#848386
11/23/07 04:13 AM
I was fixing a small rust hole on the floorboard of my 4runner near the ecu and i noticed that the carpet was wet. I looked up to and noticed that water was coming in from the radio antenna grommet and another point above that but i could not see. I checked the drivers side of the truck and it seems like i have a leak there too. Any ideas? I think i remember reading that some seams under the cowl leak but im not sure. Any suggestions would be great thanks. mine did that as well as cartermans. The windshield has rust in the channel that allows the rainwater to drip inside. The ECU got wet and required replacing on both our rigs. I wrapped my new one in a baggy and so far so good. Reseal the windscreen also
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
[Re: toyrunner]
#848387
11/24/07 08:47 PM
Thanks my truck does have some rust starting around the windsheild ill have to take it out and reseal.
1985 4runner
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.5950 MB (Peak: 0.6486 MB) Data Comp: Off Server Time: 2026-05-29 22:18:13 UTCValid HTML 5 and Valid CSS
