gears
#848610
11/24/07 08:13 PM
i was wondering if i can run 3.0 gears in the rear and 3.5 gears in the front untill i can afford to regear both axles.
thanks
2000 TJ 5" lift 33" BFG AT Rear 4-link coming soon Front hp dana 44 and frod 9" Rear coming sonn
Re: gears
[Re: kingfoss]
#848611
11/24/07 08:50 PM
YES you can! But you should disconnect the 4X4 because you will ONLY be able to use 2 wheel drive until both gears are the same.. Also the difference betwee 3 and 3.5 is prolly not enough to change.. You might want to rethink which gears you really want in there. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: gears
[Re: BigJim]
#848612
11/24/07 09:17 PM
i am going to 4.88 in it when i get the money i need to pu tthe rear axle in so the jeep can be driven again can i run 3.0 and 3.07 in 4 wheel drive?
Re: gears
[Re: kingfoss]
#848613
11/24/07 10:04 PM
Foss I betcha the 3 and 3:07 are the same gears and someone just left off the :07 from the 3... I don;t think it is possible to gear a straight 3:00 Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5982 MB (Peak: 0.6536 MB) Data Comp: Off Server Time: 2026-07-16 21:24:52 UTCValid HTML 5 and Valid CSS
