Leaky valve cover - is it ever the cover itself? #848641 11/25/07 01:06 AM
dr_time Offline OP
Recently did valve cover gaskets, and there's a small leak in the rear of the passenger side one. Is it ever a problem with the cover itself (crack/warped), and not the gaskets?
Re: Leaky valve cover - is it ever the cover itself? [Re: dr_time] #848642 11/25/07 03:11 AM
O
oldsub86 Offline
If I recall, you are supposed to put a bit of sealer in the corners. I think the FSM shows where. If you did not do that, it might be the cause of the leak.
Randy
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: Leaky valve cover - is it ever the cover itself? [Re: dr_time] #848643 11/26/07 03:08 AM
kewlynx Offline
FSM sez a thin layer of RTV in the channels on your half moon seals. Set them in place and let them cure up a couple minutes before you put the cover back on.
**ubi apis- ibi salus**
Re: Leaky valve cover - is it ever the cover itself? [Re: dr_time] #848644 11/26/07 08:49 AM
Snowtoy Offline
When I re-did mine(after the head job set), I hit all of the areas where the previous leaks were comming from, and still have a small leak. My Sister had a leak on the passenger side cover show up shortly after the dealer adjusted the valves, so simply following the FSM doesn't always do the trick. When I do them again I am going to hit the entire outer edge w/FIPG.
A crack could be the cause, but unlikely unless you over tightened a bolt when putting them back on. An inch pound torque wrench should be used over a Ft lb or hand tightening w/1/4" drive and not a lot of force.
Re: Leaky valve cover - is it ever the cover itself? [Re: Snowtoy] #848645 11/30/07 10:11 AM
dogtoy Offline
I had the same problem, assuming we are talking about a 3vze. Turned out the gaskets I purchased were not thick enough. Got the gaskets from toyota and they were noticible softer and thicker....problem solved.
2014 FJ
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6056 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-07-14 21:46:45 UTC
