Another Barn Fresh Question!!!!!!
#848860
11/26/07 12:33 PM
WOW-The Rust is just incredable!!! The front cab mounts are rusted completly through the floor-there is'nt much floor. you can really see the ground more than the floor!!! going on the cheap not pretty-can I just weld a strap across the inside of the cab(over tranny bump) or will some unknown dragon rise up and bite me in the ass!!!
79 BARN FRESH RUST BUCKET
Re: Another Barn Fresh Question!!!!!!
[Re: revman2112]
#848861
11/27/07 01:36 AM
Just pull your engine control computer and disconnect the electrics before you weld. Sometimes they can get zapped by welding.
Personally I'd take a plate of steel, pound it into shape, temper it and weld it to the under side. I'd clean up all the rusted metal in the area, weld it in on the outside being careful to have the mount height the same as original. Then I'd paint it with a rust blocker like Chassis Saver or POR-15. If you are doing all 4 mounts, then you can lift it equally at all 4. Bumper may no longer line up the best.
-- Bryan
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.5877 MB (Peak: 0.6358 MB) Data Comp: Off Server Time: 2026-06-17 16:39:19 UTCValid HTML 5 and Valid CSS
