1993 toyota 4x4 pickup v6 WHERE IS THE SPEEDO!!?? #848997 11/27/07 03:00 AM
slimdusty Offline OP
Hey guys I have an 93 toy pickup 4x4 and the speedo just stopped workin. It has rpm guage too and that is still workin and the miles are still accumulating... Any help on where it is and how I can get it workin again would be greatly appreciated!
thanks slim
Re: 1993 toyota 4x4 pickup v6 WHERE IS THE SPEEDO!!?? [Re: slimdusty] #848998 11/27/07 09:05 AM
Snowtoy Offline
Check the F'93FSM(Factory Service Manual) at the top of the forum. It could be the speedometer itself, a speed sensor, or the wire/connections could have come loose.
Re: 1993 toyota 4x4 pickup v6 WHERE IS THE SPEEDO!!?? [Re: Snowtoy] #848999 11/29/07 05:20 AM
thanks man I will try that sutff. It has not worked for 3 days and then started working again today? Does that give you a better idea of what the problem is? I dont see the service manuel at the top either???
thanks again man
Re: 1993 toyota 4x4 pickup v6 WHERE IS THE SPEEDO!!?? [Re: slimdusty] #849000 11/29/07 05:22 AM
kewlynx Offline
The FSM's are there. Look at the title of the stickys.
**ubi apis- ibi salus**
Re: 1993 toyota 4x4 pickup v6 WHERE IS THE SPEEDO!!?? [Re: slimdusty] #849001 11/29/07 09:50 AM
Snowtoy Offline
There are 3 FSM's in the second topic on this fporum's topic page, here FSM's
Since it is intermintent and the odometer is continuing to clock the miles I would think the problem is in the speedometer itself. Unfortunately the only way to check this is to pull the gauge cluster out.
Re: 1993 toyota 4x4 pickup v6 WHERE IS THE SPEEDO!!?? [Re: slimdusty] #849002 11/30/07 02:27 AM
KB1 Offline
Speedo head on '93 is likely culprit. Speed sensor wouldn't let the miles keep ticking otherwise <img src="/forums/images/graemlins/frown.gif" alt="" />. They are EXPENSIVE to get re-SCREWED! Git a yard one and go on. Or rely on the tach.
Re: 1993 toyota 4x4 pickup v6 WHERE IS THE SPEEDO!!?? [Re: KB1] #849003 12/06/07 11:53 PM
Thanks man. By speedo head you mean the needle itself right? So I can just grab a new guage cluster from a yard? The thing works one day and then not the next now...!
Re: 1993 toyota 4x4 pickup v6 WHERE IS THE SPEEDO!!?? [Re: slimdusty] #849004 12/07/07 02:40 AM
KB1 Offline
yeah, I just got the whole cluster from the donor truck that was a couple of miles down the road. I didn't have to take anything apart. Just R&R the cluster and it was good to go. Unplugs and can't mess up from harness connections. Just a pain to fool with!!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6208 MB (Peak: 0.6984 MB) Data Comp: Off Server Time: 2026-06-09 21:27:57 UTC
