2nd Gen BL Ques???? #849317 11/28/07 08:56 PM
MountaineerIsuzu1 Offline OP
My buddy has a 3 inch BL kit from an old 4 runner. Contains 14 pucks and a couple blocks. He is going to pretty much give it too me. It appears that the pucks and hardware are all ill need. Anyone off the top of thier head have a count of how many pucks the 2nd Gen Rodeo has? Are they all the same diameter? Any other parts I will need other than the fab on the steering joint?
I would take it apart myself and find out but for the next month or two its a daily so that is not an option.
I am willing to bet this has been covered before, my search combinations did no reveal any useful info though.
On a side note. Finally talked to Matt at Indy. You all were right, good folks over there. Thanks again for the info. <img src="/forums/images/graemlins/lol.gif" alt="" />
GO EERS!
Re: 2nd Gen BL Ques???? [Re: MountaineerIsuzu1] #849318 11/29/07 01:44 AM
Jonesy Offline
Not sure on the 2nd gen, but I am going to assume it is similiar at least to the 1st gen.
The 1st gen has 12 pucks......8 of the 2" diameter size and 4 of the 3" diameter. The rear ones are the ones that are the 3" diameter (2 at each corner) The rest are all 2" diameter, although I think a 3" diameter would still work in most places.
I hope that helps...at least somewhat.
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: 2nd Gen BL Ques???? [Re: Jonesy] #849319 11/29/07 07:32 PM
HCMP Offline
http://www.mjw.com/amigo/tech/frame.htm
amigo at the top rodeo at the bottom
Re: 2nd Gen BL Ques???? [Re: HCMP] #849320 11/29/07 07:40 PM
Thanks yall, I am going to give it a go, if it works great. if not then ill start over a square one.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6027 MB (Peak: 0.6588 MB) Data Comp: Off Server Time: 2026-10-22 02:15:45 UTC
