window probs #849947 12/02/07 07:25 AM
TOY84OTA Offline OP
I think the teeth on my window crank are striped, I can roll the window almost all the way up to about 3" from the top then it just slips so I push it up with my hands, but if any vibration happens it will fall back down. I have had this problem with every Toyota I have owned 2 1st gen & 3 2nd gen pickups. what makes these window crank systems fail so often. These gears seem to be weak so is there any way to fix them stronger, I don't want to fix theme with stock parts if they are prone to failure. any suggestions would help thnx
84 TOY P/U 35"Boggers 5"SUSPENTION 2"SHACKEL LIFT TRU-TRAC FRONT DETROIT REAR 5.29 GEARS COSTOM FABED BUMPERS & SLIDERS, MARLIN 4:70:1 CRAWLER T-CASE
Re: window probs [Re: TOY84OTA] #849948 12/03/07 10:40 AM
Snowtoy Offline
Common problem with the earlier Toyota's, especially those w/o A/C. There isn't a lot you can do to reinforce the gears, no way to harden them. You could fab up new ones out of steel plate, but that isn't going to be quick/easy. Fortunately you can still get replacement window regulators, check JCWhitney.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.5872 MB (Peak: 0.6355 MB) Data Comp: Off Server Time: 2026-11-04 20:50:04 UTC
