Check engine light, what is the procedure for pulling the code? #850043 12/03/07 04:17 PM
Kmartin173 Offline OP
On a '90 Amigo with a 2.6. I've searched and searched but haven't been able to find a post that describes it on my particular vehicle.
Re: Check engine light, what is the procedure for pulling the code? [Re: Kmartin173] #850044 12/04/07 01:47 AM
Jim_Paget Offline
I have the V6, but I am looking at the FSM for your vehicle right now
Connect the "Trouble Code Test" terminals with each other. (In the Trooper, these are found in the console in front of the ECM.) You can lift the little tray out of the front of the console. There should only be two connectors that can be connected together.
Turn the key to the "On" position without starting the vehicle.
The ECM will chause the "Check Engine" light to flash Code 12, indicating that the ECM diagnostics are working. Code 12 with flash three (3) times, followed by any other trouble codes stored in memory. Each additional code will flash three times, starting with the lowest code, and then start over with Code 12.
Record any codes other than 12 and post the results here and one of us with look them up for you.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Check engine light, what is the procedure for pulling the code? [Re: Jim_Paget] #850045 12/04/07 03:28 PM
No console in my Amigo, is there somewhere under the dash that I should be looking and are are there colors that I need to be looking for?
Re: Check engine light, what is the procedure for pulling the code? [Re: Kmartin173] #850046 12/04/07 04:40 PM
Jim_Paget Offline
Sorry, I missed that you drive an Amigo. One of the Amigo guys will have to tell you where the connector is. After that, the procedure is the same.
Jim Paget
www.rrr4x4.com
Re: Check engine light, what is the procedure for pulling the code? [Re: Jim_Paget] #850047 12/04/07 09:17 PM
randii Offline
The Amigo diagnostic connectors are inside the driver's kick panel, stubbing out of the thick-ish main harness.
Randii
Re: Check engine light, what is the procedure for pulling the code? [Re: randii] #850048 12/10/07 02:58 PM
I've looked all over that area but I don't see any connectors. I've got about 4 wires that have been cut for some reason, do you happen to know the wire color of the connectors?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6105 MB (Peak: 0.6802 MB) Data Comp: Off Server Time: 2026-06-07 07:24:09 UTC
