22re Intake removal '89 #850073 12/03/07 08:27 PM
Bonzai Offline OP
How do I get the intake out of the truck?
I have the wiring harness running between the runners and the outer flange, where the plenum bolts to the intake. Its loose from the block, but the harness is keeping me from getting it out of the truck.
Any tips for this situation? I would appreciate some advice.
Thanks,
Taylor
89 Toyota P/U, 22re, SAS, 4" All-Pro Fronts, Chevy rears, 33x12.50's...
Re: 22re Intake removal '89 [Re: Bonzai] #850074 12/04/07 03:28 AM
kewlynx Offline
Did you remove that 6 mm allen set bolt near the t'stat housing? Commonly overlooked.
**ubi apis- ibi salus**
Re: 22re Intake removal '89 [Re: kewlynx] #850075 12/04/07 05:26 AM
lethe Offline
i hate that thing <img src="/forums/images/graemlins/angry.gif" alt="" /> i had to unbolt the upper half on the plenum to get too it.
87' ext cab toy
Re: 22re Intake removal '89 [Re: lethe] #850076 12/04/07 06:03 AM
Bonzai Offline OP
I thought about it today, and I think the harness thats trapping the intake is probably for the oxygen sensor. It was late last nite and I just called it quits for the nite.
It just suxx that someone would put the harness thru the intake instead of around it.
Re: 22re Intake removal '89 [Re: Bonzai] #850077 12/05/07 04:15 AM
yota4runna Offline
It comes from the factory routed thru the manifold.
Re: 22re Intake removal '89 [Re: Bonzai] #850078 12/07/07 04:32 PM
Z
zoomschwortz Offline
You need to disconnect the harness and pull it through the intake.
Disconnect the O2 sensor, the switches on the tranny, the starter, oil pressure and knock sensor.
Make sure you remove the battery first.
Disconnecting the starter is the hardest part. after that is done everything else comes out in a couple minutes.
If you haven't changed your fuel filter lately, replace it now.
Take care.
Ken
89 Ext cab 22RE 5 speed
84 Ext cab 22R 5 speed
88 Mitsubishi Macro Cab 2.6 5 speed
Re: 22re Intake removal '89 [Re: zoomschwortz] #850079 12/08/07 04:00 AM
RatLabGuy Offline
I ran into this when I yanked my engine for rebuild.
It was clearly goin gto be such a pain to get the whole harness out that I decided to just lave the intake in the engine bay. I unbolted the upper plenum so the two parts were at least loosse/floppy, and folded 'em back against the fender and bungeed into place there. Held fine and out of the way whiel everything else came out.
Question Reality.
Re: 22re Intake removal '89 [Re: Bonzai] #850080 12/08/07 05:44 PM
Z
The hardest part about it is disconnecting the starter. After disconnecting the starter, everything else takes less than 10 minutes.
It looks harder than it really is.
Re: 22re Intake removal '89 [Re: zoomschwortz] #850081 12/17/07 03:29 AM
Bonzai Offline OP
Sorry for the delay. I appreciate the help, everything went fine. Getting things ready to go back together now.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6263 MB (Peak: 0.7127 MB) Data Comp: Off Server Time: 2026-11-16 08:39:47 UTC
