lift and bigger tires need some help #850299 12/05/07 02:24 AM
king063 Offline OP
I have a 1990 Stock Wrangler I'm not sure what axles that means but I am looking to put on possibly a 4" suspension lift and a 3" body and maybe some 33 swampers, are my axles going to be able to handle this or should I upgrade, does this mean getting all new axles or just different gears thanks
Re: lift and bigger tires need some help [Re: king063] #850300 12/05/07 04:59 AM
Brown81CJ5 Offline
What type of wheeling do you plan on doing? I noticed that you are wanting to put in a 350 as well. You will definitely want some gears with those 33's. Why the 3" body lift? You should only need a 1" body lift to fit those 33's pretty well. A 3" BL sounds a little top heavy to me.
My opinion would be to get a Rubicon Express 4.5" lift with a 1" BL.
With that lift though you will need a slip yoke eliminator kit if you are going to be doing any wheeling.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: lift and bigger tires need some help [Re: Brown81CJ5] #850301 12/05/07 11:30 PM
king063 Offline OP
Im not looking to do any intense wheeling just prolly like wood trails and stuff, the 350 is all just thinking haha maybe later I was just wondering if a stock 6 cyl would be able to turn the 33s easily enough for a daily driver or if things will start to wear out, axles, gears etc?
Re: lift and bigger tires need some help [Re: king063] #850302 12/05/07 11:45 PM
BigJim Offline
If you have a 90 model 6 cyl, it most likely came with a 3:07 gear in it. Putting 33's on there will cause a huge loss of horse power. Lots of trouble getting her off the line and never to see high gear again..
A 4:11 gear would be really nice in that ride. Lots of HP off the line and good usable high gear on the hiway.
Re: lift and bigger tires need some help [Re: BigJim] #850303 12/06/07 03:18 PM
burythebeast Offline
personally i would recommend swapping a ford exploder 8.8" rear with disc brakes. pretty sweet swap. The reason is, i can put a axle kit in a d30 and it will probably hold, a d35 in my eyes is junk so why spend the money on gears before u get a good axle in there..
'96 Jeep XJ
'65 Jeep CJ5
'87 Dodge Raider
'79 Plymouth Trailduster (Ramcharger)
Re: lift and bigger tires need some help [Re: king063] #850304 12/06/07 07:55 PM
BobRowe Offline
Going to 4.10 gears will help get back the power and torque you'd lose with the 33" tires.
BTW, you don't need 7" of lift to clear 33" tires. With that much lift, you could run 35" tires, but you'd then need 4.56 gears. But I don't think I'd run 35" tires on a Dana 35 axle. Ford 8.8 would be nice, but it's a little narrow. You could solve that robem with either wheel spacers or with custom offset wheels.
Re: lift and bigger tires need some help [Re: king063] #850305 12/06/07 08:15 PM
DBL_DTY97TJ Offline
BJ is right about the gears, but it's not a "huge" loss of power. I ran mine like that for a couple of years while I saved up for a better axle and new gears. He's right about never using 5th gear though. If it's an auto tranny the torque converter will mask the effect a bit. 7" lift? Don't need to go near that much.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: lift and bigger tires need some help [Re: DBL_DTY97TJ] #850306 12/06/07 10:56 PM
king063 Offline OP
what about just doing a 4" suspension and puttin on 31" or 32" tires I'm just looking for something to run for a while while I save, that wont be a dog as a daily but I can still do some light offroading, would this work?
Re: lift and bigger tires need some help [Re: king063] #850307 12/07/07 12:02 AM
BobRowe Offline
I'm not a big TJ guy, but I seem to remember that a buddy of mine fit 31" tires on his with just a set of 2" coil spacers.
Re: lift and bigger tires need some help [Re: BobRowe] #850308 12/07/07 12:59 AM
playinmud Offline
you can fit 33's with a 4 inch lift, if you dont do any highway driving 3.07s will be just fine with 33's, i have 3.07s and i get better gas millage then people with 3.73 or 4.10 with 33's, i have plenty of enough power, and i have cruised at 65mph without a problem
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6389 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-11-03 11:37:03 UTC
