Help 2001 Kia sportage Car alarm iLock #850313 12/05/07 03:30 AM
Danothemanno Offline OP
I just bought a used 2001 Kia sportage for the wife. Everytime you lock the door either with the key or the door button and close the door, when you need to get back in the alarm "horn" goes off. There is a sticker on the tthe window that says "iLock" Never heard of the car alarm and can not find anything about it on the web. Could it be a factory alarm? Can any of you help?
I do not trust the stealership to fix the problem, they would only creat more problems.
It's only been a few days but we love the car.
I just signed up, glad to be a part of the group.
2001 Kia Sportage 4x4 4dr Stock as of now
other truck
2000 Ford F250 power stroke diesel 4x4, crew cab, long bed, 265/75/16, homemade tymar intake, zoodad mod, AIH mod, CCV mod, foil delete, coolant filter, Harpoon mod, pre pump mod, crossover
Re: Help 2001 Kia sportage Car alarm iLock [Re: Danothemanno] #850314 12/05/07 06:42 AM
bombardj1 Offline
I have a 2001 too ( I live in sugarcreek ohio about 12 miles from Dover, New Philadelphia small world) ok back to your ? when you lock the kia with the key you should hear the alarm set you need to use the key to disarm it also. the buttons do not turn off the alarm. try this clsoe the driver side door lock with your key it should chirp then unlock it it should chirp again, whats good about this alarm is you can have the windows down the alarm set and it someone even lifts the button the horn goes off, do you have your owners manual ? John
Re: Help 2001 Kia sportage Car alarm iLock [Re: bombardj1] #850315 12/05/07 11:10 PM
Wow, what a small world it is. Well thanks for helping me out. So, i tried what you said....i opend the door, got out, shut the door, locked the door with the key, heard a chirp (alarm must be set).....then tried to get back in by using the key to unlock the door...horn strats blaring <img src="/forums/images/graemlins/angry.gif" alt="" /> tried it many times, it does not seem to want to chirp when i unlock the dooe, it just sets the alarm off.
1. Is this "Ilock" alarm a factory installed alram? is so i might let the stealer look at it, but not if it is an aftermarket.
2. I have down loaded the owners manual from Kis's web sight, but i did not see any instructions about an alarm, do you have a page number that i can look at?
3. I also could not find in the owners manual a fuse location for the alarm, do you know if i could disable it that way, i do not care at all about having an alarm.
4. My last resort if it is an aftermarket is to cut ou the entire alarm box, which i can do, but probable not as easy if it is a factory alarm.
Thanks for you halp
Dan
other truck
Re: Help 2001 Kia sportage Car alarm iLock [Re: Danothemanno] #850316 12/05/07 11:42 PM
A
Airdale73013 Offline
You may have a bad switch in the door lock. You have one switch wich sets the alarm when you lock the door with the key and second switch that dissarms the alarm when you unlock the door.
If you lock the door with the drivers side lock button the alarm will not set.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: Help 2001 Kia sportage Car alarm iLock [Re: Danothemanno] #850317 12/06/07 07:41 AM
bombardj1 Offline
yes it is factory, I just got home its 1:30 am my book it out in the car and it's about 0* will try and look it up when I get up. what site did you use for the manual ? I don't think there is a fuse for it. how have you been turn it off when you get in ? John
Re: Help 2001 Kia sportage Car alarm iLock [Re: Danothemanno] #850318 12/06/07 02:46 PM
bombardj1 Offline
ok I got up and went out to get the book it's near 0* burrr
ok back to the alarm, they call it theft deterent system it's on page 4-75 don't think it helps much. there some here who can help with disabling it, there should be a wire you can cut made at the door and rear hatch. John
Re: Help 2001 Kia sportage Car alarm iLock [Re: bombardj1] #850319 12/06/07 03:14 PM
bombardj1 Offline
ok this might help you need to register to use. www.kiatechinfo.com after you do sign in go to the link for shop then put in model year then click on body electrical then look for etacs look through this helpfully it might help, I will go to it and post more on how to get to it if I can. John
Re: Help 2001 Kia sportage Car alarm iLock [Re: bombardj1] #850320 12/06/07 03:21 PM
bombardj1 Offline
but don't just remove it , it controls other stuff will keep looking on what wire can be cut to the horn
Re: Help 2001 Kia sportage Car alarm iLock [Re: bombardj1] #850321 12/06/07 03:30 PM
bombardj1 Offline
ok go to the site get through all the stuff and click on etm then look for the etacs wire dia. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Help 2001 Kia sportage Car alarm iLock [Re: bombardj1] #850322 12/06/07 03:46 PM
Dude, you rock. I'm at work now and will look up the wire diagrams, and go from there. Thank you very much for all your help
Dan
other truck
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.004s) Memory: 0.6371 MB (Peak: 0.7623 MB) Data Comp: Off Server Time: 2026-06-25 03:25:52 UTC
