running hot #850568 12/06/07 06:06 AM
bud89 Offline OP
i have an 89 cherokee can't seem to stop it from over heating when not on highway. replaced waterpump,radiator,thermostat,and heater core.
Re: running hot [Re: bud89] #850569 12/06/07 07:36 AM
BigJim Offline
Bud them old vehicles have scared lots of guys.. Does it actually puke it's coolant out or does it just SHOW hot on the guage? Give us a blow by blow on the temperature.
Re: running hot [Re: BigJim] #850570 12/06/07 01:24 PM
bud89 Offline OP
it has the pressurized tank which i replaced and it is puking the fluid out.
Re: running hot [Re: bud89] #850571 12/06/07 03:10 PM
burythebeast Offline
head gasket, air in the system, could be a few things.. no water in the crankcase?
'96 Jeep XJ
'65 Jeep CJ5
'87 Dodge Raider
'79 Plymouth Trailduster (Ramcharger)
Re: running hot [Re: burythebeast] #850572 12/06/07 03:55 PM
BigJim Offline
He says "not on the hiway" Which leaves me to think the fan clutch ain't working.. The radiator ain't getting enough air until the speed increases.
So check the fan clutch.. If a head gasket is suspected there are two methods to use to check a leak out.
1. Pull the sparks and look at each one for rust..
2. Most evffective is to fill the coolant tank and start the engine let her run for a while and continue to refill the tank as the coolant completely fills the engine..
Then while running watch the level of the coolant closely looking for small bubbles. Yes the bubbles will always be there if the head gasket is leaking. They will be very small...yet visible..
Re: running hot [Re: burythebeast] #850573 12/06/07 09:42 PM
bud89 Offline OP
there is no water in crank case. i just went and bought a new clutch fan so i'll try that thanks
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6066 MB (Peak: 0.6761 MB) Data Comp: Off Server Time: 2026-07-17 07:49:09 UTC
