ABS Question #850784 12/07/07 06:19 AM
garym Offline OP
My T doesn't have it but my work truck does. Going down gravel roads when 1 wheel gets off to the side in the deep gravel while slightly on the brakes, trying to stop in slippery mud, and trying to stop in snow all cause the ABS brain to think it is skidding and I have had to change my shorts a few times. I just about hit a tree tuning around in mud today doing about 5 mph. It slid to within inches as the ABS put me into a slow rolling stop while my pedal was mashed down. Couldn't the ABS fuse be pulled to disable it if driving conditions such as above might happen? Surely, if the ABS fuse blew the brakes would still work. I am not a fan of it offroad.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: ABS Question [Re: garym] #850785 12/07/07 02:44 PM
E
eleet Offline
That may cause the trouble light to come on. Sometimes it takes a reset to get the light to go out.
97 T100 4x4
97 328i
95 540i restoration project
Re: ABS Question [Re: eleet] #850786 12/07/07 04:34 PM
ErikB Offline
Toyota Moderator
Yes, pulling the fuse or unplugging the ABS computer should disable it and your brakes will work as standard brakes. Some people go as far as removing the ABS bulb from the dash afterwards too.
I'm glad my truck didn't come with ABS. Its getting ripped out of the new 4runner. :p
http://home.4x4wire.com/erik
Re: ABS Question [Re: ErikB] #850787 12/07/07 04:59 PM
CJMT100 Offline
Which fuse is it btw?
Re: ABS Question [Re: CJMT100] #850788 12/07/07 08:49 PM
MRT100 Offline
Having active ABS when towing ON THE road is dangerous also. I know somebody who experienced that first hand when towing 3000 LB boat with his 96 4runner 4x4.
This thing just did not want to stop from relatively low speed 40 miles before an intersection.
He avoided crushing in to the car in front of him only because extra space on the side of the road.
He swears his ABS system is off for good.
He removed the fuse. I think he gets ABS warning light lit on the dashboard.
Re: ABS Question [Re: CJMT100] #850789 12/07/07 09:48 PM
adam Offline
Should be labeled on the kick panel or under the hood. Can't be more help as mine's at home convalescing and waiting for some stuff from fror.
~Adam
Re: ABS Question [Re: adam] #850790 12/08/07 01:59 AM
CJMT100 Offline
Yea I figured as much. Thus far ABS has been fine in my truck and I know in my work van what no abs is like and its odd..
Re: ABS Question [Re: CJMT100] #850791 12/08/07 04:40 AM
4
4xGeek Offline
Had quite a few pucker moments in the wifey's 4Runner... Never dare to take off in front of a fast moving vehicle - the tiniest wheel spin kills the throttle & engages the f*!@ing brakes, which is of course the exact opposite action to what I'm trying to accomplish! <img src="/forums/images/graemlins/evil.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: ABS Question [Re: 4xGeek] #850792 12/08/07 06:33 AM
CJMT100 Offline
I never had that happen, my rear tires will spin like hell if take off and its good and wet outside.
For clarification: when I jamb on my brakes from about 30mph the brakes pulsate and I hear a nice snapping back and forth noise which would bet he abs pulsating..
I am SOOOO happy my brakes are good now. I know ya'll read about my issues. all new brakes and wheel cylinders, calipers and pads and junk and I am good.
Re: ABS Question [Re: 4xGeek] #850793 12/08/07 12:45 PM
E
eleet Offline
This sounds like a traction control or stability control feature. You should be able to turn it off.
97 T100 4x4
97 328i
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6354 MB (Peak: 0.7588 MB) Data Comp: Off Server Time: 2026-06-20 19:20:33 UTC
