What happened to 5th gear? #850853 12/07/07 04:54 PM
Z
zoomschwortz Offline OP
We put a rebuilt G52 upgraded to G54 tranny into my wifes 84 pickup 2 years ago. She didn't like the stiff pressure plate and grabby clutch in stop and go traffic so it has sat in the driveway most of the past 2 years.
I would be supprised if the tranny has 2,000 miles on it.
It worked perfectly when I last drove it a couple months ago.
My Son took it for a drive the other day and said it wouldn't go into 5th gear <img src="/forums/images/graemlins/confused.gif" alt="" />
It shifts into every gear just fine but when you let the clutch out in 5th, it acts like it is in neutral. If you apply pressure to the shifter and let the clutch out, it grinds <img src="/forums/images/graemlins/scared.gif" alt="" />
What happend? If he had thrashed it (he says he didn't) I could understand a problem with 1st or 2nd, but 5th gear with a stock 22R that has 250,000 miles?
89 Ext cab 22RE 5 speed
84 Ext cab 22R 5 speed
88 Mitsubishi Macro Cab 2.6 5 speed
Re: What happened to 5th gear? [Re: zoomschwortz] #850854 12/08/07 02:54 AM
Y
yota89 Offline
Can you get it to go into gear when its not running, and how is reverse? If i remeber right if it will go into gear while not running, but not while driving then your synco probably got trashed. Its very unusal for a syncro to just go out all of a sudden, its usaually preceded by popping out of gear grinding going into gear etc..
Good Luck
89 yota pickup
22RE 261C cam
Tanny / engine rebuilt after 256K
Head machined to RV street spec(EB's)
Re: What happened to 5th gear? [Re: yota89] #850855 12/08/07 03:50 AM
kewlynx Offline
x 2
**ubi apis- ibi salus**
Re: What happened to 5th gear? [Re: zoomschwortz] #850856 12/08/07 04:42 AM
TRDSR5 Offline
5th is the first to go. Lots of peaceful folks leave it in 5th to climb hills, lug leisurely down the road or haul a load. Just like they always leave automatics in overdrive putzing around town. It's a no-no and 5th drops out. Exhuberant no talent teens generally trash 2nd <img src="/forums/images/graemlins/lol.gif" alt="" />
Turn LEFT to go RIGHT
Thudump!....What was that daddy? Ran over a Honda, go back to sleep sweety.
Re: What happened to 5th gear? [Re: yota89] #850857 12/08/07 05:39 PM
Z
It shifts perfectly into every gear, only, 5th is not there when you let out the clutch.
If you keep pushing the shifter forward after letting out the clutch, it will grind just like it would when shifting any other transmission from neutral into gear without using the clutch.
I am starting to think that the 5th gear shift fork somehow got bent. BUT HOW?
How hard is it to replace a shift fork in a G52/54 tranny?
Thanks
Ken
Re: What happened to 5th gear? [Re: zoomschwortz] #850858 12/08/07 09:57 PM
87Toy4x4 Offline
its true that 5th gear usually goes out first when your synchros die but, you should still be able to shift into fifth by rev matching.
Re: What happened to 5th gear? [Re: 87Toy4x4] #850859 12/08/07 11:15 PM
Z
I really doubt that it is the synchro since there are so few miles on it and it never had any problems going into gear. It is more like the gear isn't being pushed far enoungh to come in contact with the mating gear when it has been shifted.
When it is shifted into 5th and the clutch is let out, it will just sit there like it is in neutral but if you apply pressure to the shifter, it will grind.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6194 MB (Peak: 0.6937 MB) Data Comp: Off Server Time: 2026-07-15 02:38:30 UTC
