99 TAcoma 3.4 problem with the heat #851003 12/08/07 03:04 PM
DJN Offline OP
So this seems a little weird to me, but I'm having problems with the heat in my truck. I have the heat cranked all the way to hot and the only vents that blow out hot air are the floor vents....defrost at best is luke warm and dash vents are luke warm at best as well. It's Damn cold here in MN right now!!
Think it could be the thermostat or the heater core?????
Not even sure where the thermostat is on this beast.
Re: 99 TAcoma 3.4 problem with the heat [Re: DJN] #851004 12/09/07 12:36 AM
W
Whizkidder Offline
Some random thoughts:
First, since you seem to have heat at the floor vents, your "mix" door or linkage may be the problem. I think your truck has a physical cable from the heat control to the mix door, but I'm not sure. (Later models have electric motors to control the movement of the vanes inside the heater box).
Second, if your truck has had the thermostat replaced, it is possible that you have a lower temp thermostat. I believe the OE spec is 180F or 82C. When I installed the TRD 7th Injector kit in my truck, it came with a 160F thermostat. That was okay in Savannah, GA, but winters here in D.C. are a bit colder. I just put my 180F back in my truck today so that the heater will put out some heat -- the 160F would barely let the heater keep up when the temps dropped below 30.
You should also check to ensure that the heater (water) control valve (on the firewall behind the intake manifold) is opening fully when your heat control is turned up. Loose linkage or a bad/plugged water valve could also limit the amount of heat you can get inside the cab.
Good luck, and let us know what you find.
Re: 99 TAcoma 3.4 problem with the heat [Re: Whizkidder] #851005 12/09/07 03:35 PM
Dandeman Offline
Toyota Moderator
Don't know if the Tacoma uses the same heater air flow housing and "mix door" design, but my 2000 4Runner had the same problem..
There's an external cable that goes down the heater (on the side facing the passenger seat) and a cable clamp on the bottom of the heater.. If the cable housing slips out of position, the mix door won't operate... and causes cold air to come out even with heater controls in max heat position.
A simple repositioning of the cable and tightening the clamp fixes the problem...
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.015s) Memory: 0.5973 MB (Peak: 0.6516 MB) Data Comp: Off Server Time: 2026-11-04 19:57:20 UTC
