Oil Pump #851068 12/09/07 01:36 AM
fleetbob1 Offline OP
Help,,,,,,
I took all the bolts out of the oil pump on my 1990 Montero 3.0 and i cant get the oil pump to come off more than 1/4 inch after much prying i think i screwed it up I will replace it -----but how do I get the old one off ???
1990 Montero LWB V6 5-SP Locked Rear/33/12.50 Kumho KL-71 Mud Terrains/3" body lift,bars/springs/poly/shocks/custom skids/lots of lights/snorkle/etc......
Re: Oil Pump [Re: fleetbob1] #851069 12/09/07 01:46 AM
FrankR Offline
It pulls straight off..... but first you have to remove the crankshaft key. The key won't keep the pump from coming off, but it will cut the seal on removal.
The pump body fits over 2 dowel pins that may be burred and holding it in place. Try prying gently at the outer edges.
Frank
Re: Oil Pump [Re: FrankR] #851070 12/09/07 01:55 AM
I pried the crap out of it ---to the point of no return---i orderd a new pump ---will have it Monday
The only thing i can think of is that there is alittle corrision on the crank or the pump is cocked.
Re: Oil Pump [Re: fleetbob1] #851071 12/09/07 02:17 AM
FrankR Offline
You did remove the crankshaft sprocket, right? That's the part that usually hangs up from corrosion..... sometimes they have to be coaxed off with a cold chisel.
Frank
Re: Oil Pump [Re: fleetbob1] #851072 12/09/07 02:20 AM
Is the oil pan on or off the engine?
Re: Oil Pump [Re: FrankR] #851073 12/09/07 02:22 AM
all is off the timing belt pully came off easy as did the woodruff key---the pump seems to be stuck on the crankshaft
the front 4 oil pan bolts are off and i broke the seal with a putty knife
Re: Oil Pump [Re: fleetbob1] #851074 12/09/07 02:34 AM
How about the oil pickup tube that bolts to the oil pump?
Re: Oil Pump [Re: OldColt] #851075 12/09/07 03:16 AM
FrankR Offline
Good thought. I assumed that was off - maybe not.
Frank
Re: Oil Pump [Re: FrankR] #851076 12/09/07 05:51 AM
I dont think its connected
all Data doesent say anything about unbolting it or removing the oil pan
Re: Oil Pump [Re: fleetbob1] #851077 12/09/07 06:53 AM
FrankR Offline
It's connected. AllData didn't include all of the data. <img src="/forums/images/graemlins/scared.gif" alt="" />
You will now need to either hoist the engine an inch or so - or drop the differential - in order to remove the oil pan and remove the oil pickup. The oil pickup has 4 bolts - 2 on the oil pump and 2 on the brace legs that are attached to the bearing girdle rails.
Even if there was no oil pickup (and there is), the oil pan has to come off before you can remove the pump and reinstall another.
I'm curious as to why you need to remove the pump.
Frank
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6423 MB (Peak: 0.7651 MB) Data Comp: Off Server Time: 2026-11-15 15:58:14 UTC
