Rating: 5
Page 27 of 78 1 2 … 25 26 27 28 29 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851377 04/01/09 04:18 AM
G
Greg_Canada Offline
There's a place in Fonthill (about 20 min from niagra falls) where i'm going to pick some up. Damplifier is about $3.50 / sq ft. Oh yeah, anything that comes on a "roll" or is rolled up, isn't meant for cars, it's meant for roofing. If it comes in sheets, it's meant for a car. I've learned that in my searching (dynamat extreme and damplifier come in sheets) The b-quiet stuff comes in rolls (made in alberta) .
Here's a cool site: http://www.sounddeadenershowdown.com/
89 4Runner
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Greg_Canada] #851378 04/02/09 12:49 AM
CJM Offline OP
had an hour today ... so I thought I would start on the floors .. got them drilled , and fit again , and started to "plug" the holes ..
got a couple done and ran out of wire .. crap !! I hate when that happens <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" />
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851379 04/03/09 12:49 AM
CJM Offline OP
tacked !!! <img src="/forums/images/graemlins/smile.gif" alt="" />
still have to modify the seat crossmembers to fit (there just sitting there ) and weld the nuts before I can weld them in --- but kind of shows you the seat support .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851380 04/10/09 11:30 PM
CJM Offline OP
couple of things today ..
got the seat belts installed / mocked up
I do have to still plate the mouinting bolts on the floor , but I will do that when I have the cab off .
also removed the air intake muffler , and made a pipe . this pipe diameter is 2.75" and seems no one in town has .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851381 04/12/09 12:28 AM
CJM Offline OP
continued with the floor mock up ...
but first had to replace the seat tracks .... some one cut and welded the rails >:(
i'm going to re-do the seats anyway , so no biggie !!
removing the seat back cover , lock strip and hog rings .
and installing the new rails ...
with the new rails , I now could line up the rail , and weld mounting bolts .. and zinc .
aligned , and welded
and seats ... BOLTED smile
[img]http://i76.photobucket.com/albums/j2/bj_bumperboy/MY%20Trekker/HPIM1381.jpg[/img]
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851382 04/13/09 12:33 AM
CJM Offline OP
couple of more things ....
buttoned up the heater control valve , and hoses including the rear heater piping ...
also
got the new fan installed .. I decided to take back the 14" 1500CFM in favor for the 16" .. 2500 CFM
had to cut the lower support .. but no biggie ..
made a new hood lock support , "boltable"
just now waiting for the fan controller now .. :-/ (ordered a week ago )
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851383 04/23/09 12:38 AM
CJM Offline OP
so not much to add ... built the box for the body computer .. and I'm just awaiting my new fenders to check clearances .. I want to move out as far as I can to alow for inner kick panel clearance ..
also got my new Optima battery
and also just got to day for the wiring near the exhaust ... some heat tape smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851384 04/23/09 07:16 AM
F
flyinhawaiian Offline
sweeeeet, awesome job. kinda envy how you have the space and time to do this work...by the way, is that heater valve oem? aloha. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: sold the first one .. so this ones mine ... Trekker Build [Re: flyinhawaiian] #851385 04/23/09 03:37 PM
CJM Offline OP
thanks , I wish I had more space and time .. fishing and camping soon , and also coaching my boys ball team ... not much time for me .
Yes heater control valve is from a 89 4Runner 3.0L with rear heater . hoses and all fit excellent . I changed the routing of the rear piping for the rear heater though , I am using 14" of copper for each line , only to get by the crossover pipe , then I'm going to route rubber hose , and insulate it for better rear heat .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851386 04/26/09 01:17 AM
CJM Offline OP
so spent a few bucks today ...
bought some shop tools and consumables , and some dollies . I wanted to put some tires and wheels on it , and the dollies will just make it that much more maneuverable ..
so .. I put the shoes on for mock up (they dont fit quite right as they hit the calipers) and got it on the dollies .. also got the fiber fenders set on to check the body computer box clearance .. fits perfect smile , so now I can weld that ....
so now I can push it around the shop .. I thought I would do a full body mock up ... hehehe .... enjoy .. I did
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.023s Queries: 16 (0.019s) Memory: 0.6639 MB (Peak: 0.7900 MB) Data Comp: Off Server Time: 2026-11-03 04:50:12 UTC
