Rating: 5
Page 40 of 78 1 2 … 38 39 40 41 42 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: matts] #851507 10/13/09 01:40 AM
CJM Offline OP
Matts ..
yes , they are on the website + the 2nd gen door skins are comming very soon .. I have some rear 89-95 hi-clearance box skins hitting the market next , install comming soon !!
hinge pins are a "generic" set .. about $5.00 per .. and the should be avaliable at your local parts store
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851508 10/16/09 10:00 PM
1
1986xtracab Offline
how well do those nut-certs work? I have been interested in them for a while but don't know anyone that has used them.
1986 xtra-cab 22re
stock everything
1991 bed
Re: sold the first one .. so this ones mine ... Trekker Build [Re: 1986xtracab] #851509 10/17/09 01:53 AM
CJM Offline OP
I love em' .. I have been using them for just about 30years now ..
so as mentioned .. center console is now mounted .. got the gauges in .. also started to re-do the dash again !!! I think this dash has been the hardest thing of all .. you look at it all the time , and I'm trying to get the "best" aesthetic value I can ..
I hope this is the last time !!!
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851510 10/18/09 12:42 AM
CJM Offline OP
so .. done , well "rough in" anyway smile
I'm very pleased , and will be able to look at it for a long time .
I went with the /83 ashtrey , and the /99 lighted , cig lighter .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851511 10/18/09 12:51 AM
K_Raider Offline
I thought you were leaving the ashtry out? It looks great. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: sold the first one .. so this ones mine ... Trekker Build [Re: K_Raider] #851512 10/18/09 01:49 AM
CJM Offline OP
I was .. and thanks by the way .. but since I removed the guages and installed them into the console , I had to fill the space with something !! .. I'm satisfied with the look now (3rd time), so I can now move on
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851513 10/23/09 01:19 AM
RatLabGuy Offline
Ash trays are great for loose change and random screws anyway...
Question Reality.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: RatLabGuy] #851514 10/25/09 01:25 AM
CJM Offline OP
thats what I figured as well !!
got everything in the dash "mounted" today .. made all the little clips and mount brackets .. and welded them all in place . so now they can easly be removed , but wont be falling out . smile
I have also changed my plan for the dash .. I wont be doing the woodgrain .. I'm going to paint the main dash and center console the "inferno red" , same color as the outside , with the cover/pad being grey leather to compliment the interior all the dash trim is going to be painted black
I now just have a few little dash lamps and such to wire , and I believe then , I am ready for the tear down
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851515 10/29/09 01:14 AM
CJM Offline OP
passenger door "epoxied" and curing overnight .. also got a little more done on the wiring .. had to add and move a few plugs for the lighter and such also got all 4 accessory ports wired .. drilled and set into place . I want to add the cup holders to the console , and maybe a "pocket" as well ..
have some pics up tomorrow
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851516 11/01/09 01:02 AM
CJM Offline OP
ok .. so I believe I'm all done the wiring now smile .... Finished up the guages (now green) almost time to sauder all the cinnections , and tape and loom .
also did the new dome lamp in the rear ,
and a "walk-in " lamp wired to the auto shut off lamp system , I will install it down in the foot area when the time comes .
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.052s Queries: 16 (0.049s) Memory: 0.6584 MB (Peak: 0.7803 MB) Data Comp: Off Server Time: 2026-10-22 04:04:55 UTC
