Rating: 5
Page 51 of 78 1 2 49 50 51 52 53 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851617 05/14/10 03:26 AM
trcdrunner Offline
I remember the part supra part mini truck... all monster.... <img src="/forums/images/graemlins/lol.gif" alt="" /> Still cant wait for the trekker thou... BTW U R A MAD MAN
- Nice work <img src="/forums/images/graemlins/cheers.gif" alt="" />
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: sold the first one .. so this ones mine ... Trekker Build [Re: trcdrunner] #851618 05/15/10 01:45 AM
CJM Offline OP
thanks .. me to .. I'm stoked to get the trekker finished ..
so a little bit today ... now that the cab is in the paint shop .. I needed to paint some pieces myself..
satin black
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851619 05/16/10 01:41 AM
CJM Offline OP
and the dash bezzles smile
same satin black
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851620 05/21/10 12:58 AM
CJM Offline OP
I checked in on the paint today .. and it will be " hi-build" primered tomorrow smile and then inners will be colored next week I hope ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851621 05/24/10 01:09 AM
CJM Offline OP
so a little bit more today ...
got the alignment done , and locked down .. steering damper is also now attached ..
replaced the spark plugs with a heat range lower and platenum tipped ($80.00 bucks) and also a lower temp 170* gates # 33867 thermo .
front drive shaft is now in the works ..
some cleaning and POR15 in the works ...
on the front part of the drvshaft .. under the u-joint , there is a plug ... I have misplaced the size /part #
anyone know it ?
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851622 05/24/10 07:01 AM
kewlynx Offline
Plug or a zerk fitting?
**ubi apis- ibi salus**
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx] #851623 05/24/10 04:27 PM
CJM Offline OP
plug ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851624 05/25/10 01:25 AM
CJM Offline OP
got everything back together today . I checked some of the aftermarket stores today, for the dish style frost plug and had no luck , most wern't open today because it was a holiday , so I ended up taking the plug out of an old shaft I had from another truck that I parted out ... I "miked" it .. and was 34.25MM .. if anyone is ever interested..
anyway .. I install the plug , and cleaned and washed and prepped for the POR15 coating ...
Chassis is now complete .. (once I bolt on the front shaft) ... only thing left to do is the Gear oil ...
everything is done smile and ready for the cab
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851625 05/28/10 01:49 AM
CJM Offline OP
ALL gear oils changed today ...
also picked up the locks .. ALL were re-key'd to match ..
i'm ready for the cab !!
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851626 05/29/10 06:03 AM
CJM Offline OP
worked on the rear door today while my boy was at ball practice ... no I'm not coaching this year!!
fit the new inner cover .. and also glued the rear door skin back on to the frame ..
also painted the shifters .. <img src="/forums/images/graemlins/notooth.gif" alt="" />
cab should have been primed today .. I guess I'll see on Monday
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.026s Queries: 16 (0.023s) Memory: 0.6598 MB (Peak: 0.7822 MB) Data Comp: Off Server Time: 2026-07-15 00:20:51 UTC
