Heat not working when stopped....help!!!
#851897
12/09/07 05:59 AM
Heat works great after it warms up until I stop at a stoplight. Then it just blows cold air. Anybody know what the deal is?
Re: Heat not working when not moving....help!!!
[Re: enutter]
#851898
12/09/07 10:06 AM
Well, sounds like a thermostat that isn't closing properly to me.
Dave
[Re: enutter]
#851899
12/09/07 06:55 PM
Does the temp gauge on the dash come up to the middle? If so, thermostat is probably OK. Sounds like low coolant, or a trapped air bubble.
[Re: yota4runna]
#851900
12/10/07 05:21 AM
Temperature guage is right in the middle. Coolant level was just checked. How would one go about getting rid of this bubble?
------------------------------------- "E" Nutter 1988 Toyota 4runner 3.0 V6, some mods
"JUST SAY NO TO NWOR"
[Re: enutter]
#851901
12/10/07 05:23 AM
Park the truck on an incline, or jack up the front end. Make sure your front and rear heat selectors are set to HOT. Remove the radiator cap (make sure truck is cool) and start the engine up. Let it get up to temperature. Careful, you may spill some coolant out in the process. If there is a bubble, you should see it come out of the radiator.
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.015s) Memory: 0.6045 MB (Peak: 0.6688 MB) Data Comp: Off Server Time: 2026-11-18 11:39:02 UTCValid HTML 5 and Valid CSS
