Coolant flush #851957 12/09/07 08:00 PM
89montero Offline OP
I need to flush the cooling system in my 89 LWB, I don't know when it was last done. From what I read I just drain the coolant, fill it with some kind of cooling system cleaner, drive it around for 1/2 hour with the heat on hot, then drain the cleaner and fill with coolant.
Is this the correct procedure? What is the best cleaner to use?
Thanks,
-Colin
1989 Montero 4dr V6 3.0l
Re: Coolant flush [Re: 89montero] #851958 12/09/07 08:55 PM
Two245Turbos Offline
That's pretty much about it....I'm contemplating doing mine today...I's snowing out right now though...
RB
'95 Montero SR , 31x10.5 Yokohama Geolandar AT II,
Thule box.
Car
Re: Coolant flush [Re: Two245Turbos] #851959 12/09/07 09:05 PM
G
generation_one Offline
If you must use a chemical follow the directions
and always use distilled water.
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Coolant flush [Re: generation_one] #851960 12/09/07 09:43 PM
what would you recommend as the best brand? It's kinda gummed up so I'm willing to spend some extra $$ and use something heavy duty
Re: Coolant flush [Re: 89montero] #851961 12/09/07 10:15 PM
52degrees Offline
I'll tell you what I did, but no-one will like it.
I replaced the water pump. When I had it off, I stuck a garden hose in one water pump hole and turned it on until it ran out completely clear. Then I pulled a heater hose and did the same thing.
It's not going to remove the scaling that a chemical flush will, but I know that there isn't any alkaline flush crap left in my system either.
By the way, Prestone makes a really good chemical flush. It's 2 parts. The first is the flush chemical. The second part is the neutralizer for the flush. It cleans EVERYTHING from the inside of the block. Sometimes leaks develop that hadn't shown up before as a result of this flush. These leaks are almost always because dried coolant crystals and sludge were plugging the leak.
KG6VNX
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6067 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-11-02 12:27:02 UTC
