how to unblock heater core #851962 12/09/07 09:52 PM
V
v8yota Offline OP
hi,,,what is the best way to unblock the heater core on a 93 toyota 22re
Re: how to unblock heater core [Re: v8yota] #851963 12/09/07 10:46 PM
4Crawler Offline
Disconnect hoses at firewall and back flush with a garden hose until the water runs clear. Then forward flush and repeat a few times until the water flows clear both ways.
Re: how to unblock heater core [Re: 4Crawler] #851964 12/10/07 12:12 AM
yota4runna Offline
Works great if you apply pressure slowly. Some city water systems have enough pressure to blow the heater core if you pressurize one that's really stopped up too rapidly. Ask me how I know!
Re: how to unblock heater core [Re: yota4runna] #851965 12/10/07 12:15 AM
4Crawler Offline
Yes, that is true. I use a trigger nozzle with a tapered end and shove that into the hose then slowly open the nozzle until water comes out the other hose. You can also see if back pressure is building up if water starts squirting back out of hose the nozzle is inserted in. Also, best to back flush (water into the outlet line) first as that will tend to push the clog back out the way it came in originally.
Re: how to unblock heater core [Re: 4Crawler] #851966 12/10/07 03:41 AM
V
v8yota Offline OP
thanks ,,,,which one is the inlet
Re: how to unblock heater core [Re: v8yota] #851967 12/10/07 04:09 AM
OOP'S Offline
The one with the on/off valve on the firewall.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: how to unblock heater core [Re: OOP'S] #851968 12/10/07 10:49 PM
V
v8yota Offline OP
ok ,,thanks
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6179 MB (Peak: 0.6919 MB) Data Comp: Off Server Time: 2026-07-16 03:40:52 UTC
