Gen1 5spd to Auto #852056 12/10/07 03:53 AM
franklynberry Offline OP
I'm sure this subject, converting a 5 speed to automatic, has been covered to death. Can someone suggest a search for the archives?
Can't seem to make it narrow enough.
--f
'88 SWB 5-speed Megasuirt MS-II V3 Starion TBI N/A 650/950cc Injectors 4Runner Alloys 275-70R16
Re: Gen1 5spd to Auto [Re: franklynberry] #852057 12/10/07 08:24 AM
LRJ4x4 Offline
You have to use quotes like "auto conversion"
I'll save you some time....Montero's are cheap buy one with a Auto already in it. It's WAY less trouble. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Now if your retired and looking for project to fill up some time by all means, go for it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Gen1 5spd to Auto [Re: LRJ4x4] #852058 12/10/07 06:51 PM
Thanks. That helps.
... and WAY unavailable up here in the upper midwest. Most died of rust 10 years ago. As a neighbor noted last week, parts are getting real hard to find, and boneyards haven't had a pick to pull in a decade.
Good news: the G54B on EFI w/o turbo makes a TON of mid range torque. Bad news: fasteddy told me so. 33's, a torquey motor, and a KM-148 cannot co-habitate at 80 mph. i lost my SECOND set of layshaft teeth <1st, 2nd, 3rd, 5th, and reverse go wheeee-bang! at one time>in 10K miles. More good news: i had enough torque to limp 400 miles home in 4th gear alone. Including 5 stops for gas <yikes!>.
Anyone wanting to clear their garage of the "setup" parts for an auto conversion should drop me a note in PM. I've found an auto and auto xfer case for a reasonable amount, locally --- but need everything else.
Last: I have a spare 5spd xfer case. Is it convertible to auto use? One of fasteddy's posts would seem to imply this is possible. If it is, can I use the 5spd drive shafts? or is the case in a different PLACE, requiring a different drive shaft length?
--frankb
Re: Gen1 5spd to Auto [Re: franklynberry] #852059 12/10/07 07:15 PM
NathanC Offline
If you want another 5speed, I have one. Its supposed to be in good shape, but I can't personally vouch for it.
The bad news is that it is from a pickup and they used cable-actuated clutches instead of hydraulic. <img src="/forums/images/graemlins/confused.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: Gen1 5spd to Auto [Re: NathanC] #852060 12/10/07 07:48 PM
Thanks for the offer Nathan. This is the 5th 5 speed tranny this truck has seen. It will NOT see a sixth, at least not on my watch...
Re: Gen1 5spd to Auto [Re: franklynberry] #852061 12/10/07 09:15 PM
NathanC Offline
Hehe, yeah, I've gone through a few myself. That's why I'm going auto. <img src="/forums/images/graemlins/pfft.gif" alt="" />
'88 Mighty Max
Re: Gen1 5spd to Auto [Re: NathanC] #852062 12/10/07 11:54 PM
W
whitelespaul Offline
I'm having mine converted as we speak. The crossmember isn't that much different from the 5 speed. We ended up using a universal B and M cable shifter from Summit racing. It is a 3 speed shifter; I just need to add a switch for the OD IIRC. The rear driveshaft in my pickup had to be shortened and the front lengthened by a couple inches. The input splines are different from auto to manual on the TC.
83 mitsu flat bed 2.6l weber, 88 auto tranny, 2" body lift, 4.625 LSD, 235/85-16E mudders (33 x 9.50).
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6147 MB (Peak: 0.7097 MB) Data Comp: Off Server Time: 2026-06-17 02:59:00 UTC
