Timing light recommendations?
#852348
12/11/07 10:42 PM
I want to buy myself a timing light and I wondered what people thought as far as brands, where to buy etc. All suggestions welcome. I'm located in south west British Columbia.
91 SR5 Xtra Cab, 298000km, 4" lift, 56" rear springs, 33-12.5R15 BFG Mud-Terran T/A KM2.....and an '85 axle still waiting to go in.
Re: Timing light recommendations?
[Re: rovers1973]
#852349
12/11/07 10:49 PM
I got one like this from JC Whitney: ![[Linked Image]](http://www.jcwhitney.com/wcsstore/jcwhitney/images/imagecache/G_18166G_SW_1.jpg) Has a nice digital RPM and advance readout. Clips onto the #1 plug wire. The advance feature is nice as you can use the easier to see TDC mark for setting the timing instead of the smaller one at 5BTDC (22R/RE) and if you want to vary the timing outside 0 or 5 degrees, you don't have to guess how many degrees you are setting it to.
[Re: 4Crawler]
#852350
12/12/07 05:17 AM
that looks alot like the one that I have. it also helps to find the timing marks and paint it with white out.
[Re: missouriman]
#852351
12/13/07 02:10 AM
Unless you plan to use it a lot, like a shop. Then any cheapy inductive style light will work. Timing don't move once you set it properly. I have a Snap-on light but bought it at a yard sale - looks a lot like 4crawlers.
I buy good tools and test equipment at pawn shops - haggle with them an you often get a deal ! I bought a ball joint seperator tool this morning for $10.00 - they had no idea what it was. I typically act interested but also like I could care less - it usually works for me. Oh and this just in - cash talks.
<img src="/forums/images/graemlins/smile.gif" alt="" />
Just an OLD hippy with lot's of experience !
[Re: Doc279]
#852352
12/14/07 02:47 AM
Cool, thanks for all the info guys. Much appreciated.
[Re: rovers1973]
#852353
12/19/07 08:02 AM
That one 4crawler shows is the Equus/Innova brand one. Check them out here: http://www.iequus.com/products.php?category_id=1_20 I bought one of theirs also, and have been happy with it. Search Amazon for "Equus timing" and you can get the $200 model for $119. Hope this helps.
Jeremy 88 Toyota Pickup 22RE, 31x10.5's, Warn M8000, Marlin rear bumper
[Re: mudking82]
#852354
12/19/07 10:21 PM
Thanks for the feedback guys. Helps make my decision easier. Will let you know what I end up with.
[Re: 4Crawler]
#852355
12/20/07 07:03 AM
I got one like this from JC Whitney: ![[Linked Image]](http://www.jcwhitney.com/wcsstore/jcwhitney/images/imagecache/G_18166G_SW_1.jpg) Has a nice digital RPM and advance readout. Clips onto the #1 plug wire. The advance feature is nice as you can use the easier to see TDC mark for setting the timing instead of the smaller one at 5BTDC (22R/RE) and if you want to vary the timing outside 0 or 5 degrees, you don't have to guess how many degrees you are setting it to. X2 on this one. me and the master tech im apprenticing under use this same light in the shop. works great.
formerly 277000_yota Old enough to know better, but still to damn arrogant to care... ]www.cardomain.com/ride/2614269'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P) '98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
