Re: PRESS RELEASE Independent4x announces the NEW 12 bolt Locker [Re: strawmyers] #852533 01/13/08 03:29 PM
W
Wareagle Offline
Sean is right. You cannot just swap the entire 3rd since the VX has a 4.30 ratio and trooper has a 4.56. You will need to swap the carrier only from an open 3rd into the VX 3rd. Once they are swapped, you will need to check backlash and engagement pattern.
Re: PRESS RELEASE Independent4x announces the NEW 12 bolt Locker [Re: Wareagle] #852534 01/14/08 03:01 AM
matthew Offline OP
VX uses the same rear axle as the 92-97 trooper
you could also use this as an opportunity to do a gear swap.......you could get an open 4.56 rear 3rd and also swap in a front 4.56 10 bolt 3rd
lots of cool options for hte VX owners <img src="/forums/images/graemlins/wink.gif" alt="" />
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: PRESS RELEASE Independent4x announces the NEW 12 bolt Locker [Re: matthew] #852535 04/18/08 10:56 PM
TrooperXS Offline
Matt,
Awsome job i think it's great that you have a 12 bolt locker coming out as well as a 10 bolt and the 3.07 gear set's I'm definetly looking forward to ordering them.
- Jason
2004 GMC
1987 Samurai
Go Army
Re: PRESS RELEASE Independent4x announces the NEW 12 bolt Locker [Re: TrooperXS] #852536 04/23/08 03:37 AM
matthew Offline OP
all these products are out and shipping.
thanks for the props. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: PRESS RELEASE Independent4x announces the NEW 12 bolt Locker [Re: matthew] #852537 10/26/11 12:10 AM
throwin_roost Offline
awesome sounds good.
93 Rodeo 3.2L, 3" body lift, 3" Indy4x lift on 33's, flowmaster50, stainless brakes and clutch lines,
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.003s) Memory: 0.6136 MB (Peak: 0.6939 MB) Data Comp: Off Server Time: 2026-05-29 21:07:28 UTC
