slipe yoke to fixed?? #852870 12/14/07 12:04 PM
spacecab90 Offline OP
I searched...
I have a blown transmission from my bros 93 RS trooper sitting in the garage, and the rear output is a fixed flange style deal. Can i replace the rear of my slip yoke transfercase with the rear of his, on my 1990 pickup?
Thanks
Joel
1990 Isuzu Spacecab, SAS 95% done
'06 Nissan Sentra SE-R Spec V
Re: slipe yoke to fixed?? [Re: spacecab90] #852871 12/14/07 12:10 PM
strawmyers Offline
Isuzu Moderator
The back half will physically bolt to your case; but you have the swap the "innerds" ( <img src="/forums/images/graemlins/notooth.gif" alt="" /> ) as well. Or if you have Tera Lows, you will have to buy the other set for the fixed yoke rear output. Some info on the topic, and a pretty detailed alternative in this thread:
DIY Fixed Yoke Rear Output
And info here: What Gearset Part # For Fixed Yoke Case Swap
Sean Strawmyer
Re: slipe yoke to fixed?? [Re: strawmyers] #852872 12/14/07 02:11 PM
RobG Offline
I did this combined with a spare fixed yoke cover I had sitting around to get our '89 RS converted to fixed yoke.
-Rob
Re: slipe yoke to fixed?? [Re: RobG] #852873 12/15/07 04:44 AM
I knew it could not be that easy..
Say that I do not have Teralow's at this point, and lets just say that I really want them haha. Would I have to shell out for both the fixed yoke and the slip yoke version to swap over the fixed yoke rear, or can i just get the fixed yoke Teralow's and be good?
Thanks for the help, I saw mclarks conversion when I searched, I will probably end up doing that, if this doesnt work out.
later
Joel
Re: slipe yoke to fixed?? [Re: spacecab90] #852874 12/15/07 07:31 PM
strawmyers Offline
Isuzu Moderator
Since you have a donor fixed yoke case to rob parts out of; my understanding from reading through the second thread is that you can get by with just the fixed-yoke Teras.
Sean Strawmyer
Re: slipe yoke to fixed?? [Re: strawmyers] #852875 12/15/07 08:19 PM
RobG Offline
This is what I did. I ordered Tera's for the fixed yoke and from my donor case used the fixed yoke rear cover and hi-lo gear, shift collar, and brass synchros.
-Rob
Re: slipe yoke to fixed?? [Re: RobG] #852876 12/16/07 02:13 AM
Excellent, Thanks guys. It sounds like I might have bigger problems to deal with now. Awful grinding sounds in the transmission <img src="/forums/images/graemlins/angry.gif" alt="" />. Oh well, thats the one part of this truck that i havent torn apart yet.
Thanks again for the help.
Joel
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6207 MB (Peak: 0.7127 MB) Data Comp: Off Server Time: 2026-05-27 17:02:07 UTC
