tailgate window motor the same as door motor? #853091 12/15/07 07:49 PM
jwheelin1 Offline OP
I don't have power door windows so I can't look. I need a tailgate window motor and seem to remember hearing that it is the same as the door motors. I see "left" and "right" and "tailgate" part numbers that are all different. Is the tailgate motor the same as the right or left? I will be looking around the local yards and the more options I have the better. Thanks. Jeff
Re: tailgate window motor the same as door motor? [Re: jwheelin1] #853092 12/15/07 08:06 PM
G
Greg_Canada Offline
Some dude sent me this,
I saw your post on 4x4wire.com that you TIG welded a
tooth back on the rear tailgate motor for your 1989
Toyota 4-Runner well you can rust free motors for them
off cars like:
4-Runner rear tailgate window motor:
A)80Æs Celica/Supra
B)87-91 Camry (left or back door) Toyota #
85720-32040,NipponDenso # 062100-2410
C)passenger side door power window motor out of Camry
D)Mazda 323 or 626Æs passenger or driverÆs side window
motor two of the holes line up while the 3rd needs
filing.
some all that is needed is swapping the harness
plug
89 4Runner
Re: tailgate window motor the same as door motor? [Re: jwheelin1] #853093 12/17/07 04:19 AM
yota4runna Offline
Got a tailgate window that won't go up and down? Run 12 volts directly to the motor to make sure it's bad, first. It's my experience that these motors are usually OK and that the problem is usually in the complex electrical interlock system. A terrific resource for checking this system is linked here:
http://www.4crawler.com/4x4/CheapTricks/RearWindow.shtml
Re: tailgate window motor the same as door motor? [Re: yota4runna] #853094 12/17/07 04:44 AM
The window has been moving very slowly for a while now and has been making horrible grinding noises. I pulled the motor and the window moves easily in the gate. Cleaned and lubed the regulator gears and tracks. Motor moves slowly and sounds horrible on the bench. Time for a new one. I guess I can't complain too much. It did last for almost 20 years. Now the fun. Finding one that I don't have to trade a kidney for. All the yards seem to want a lot for them.
Re: tailgate window motor the same as door motor? [Re: jwheelin1] #853095 12/17/07 04:53 AM
4Crawler Offline
Don't condemn the motor, check the voltage coming out of the relay box. If the motor is not getting nearly the full battery voltage, there is something causing a voltage drop in the system and low voltage = low torque at the motor = slow operating speed. A replacement motor would work just as slow in this case.
Re: tailgate window motor the same as door motor? [Re: 4Crawler] #853096 12/17/07 06:21 PM
D-runner Offline
I replace the tailgate motor a couple years ago. I used one from a Toyota car with power windows (look for Toyota cars, trucks and vans) but I canÆt remember if it was the driver or pass side. Just take the old one with you to the JY and compare. Do check the plugs because Toyota did use two different types, one that is round and one that is square (I have the round type). The one I used bolted right in but I had to reverse the two wires so that the switch worked correctly.
Adam W.
87 4Runner SR5 - 22RE w RV head & TRD Cam, LCE header, W56B-HD, 4" Stage II, 1.5" BJS, Rancho T-bars, F 5.29, R 5.29 ARB V6 FF w LC disks, 35" MT/R's
85 4Runner frame, 5" Marlin springs, 5:29 ARB HP front. Work in progress - Always!
Re: tailgate window motor the same as door motor? [Re: D-runner] #853097 12/17/07 06:41 PM
G
Greg_Canada Offline
Do people even read my posts?
89 4Runner
Re: tailgate window motor the same as door motor? [Re: Greg_Canada] #853098 12/17/07 06:45 PM
RatLabGuy Offline
I don't think so <img src="/forums/images/graemlins/drunk.gif" alt="" />
Question Reality.
Re: tailgate window motor the same as door motor? [Re: RatLabGuy] #853099 12/17/07 08:35 PM
4
4runner4ever Offline
What did you post? <img src="/forums/images/graemlins/smile.gif" alt="" />
Black '90 4R
SAS with LC80 coils and LC70 high pinion axle
LC80 rear axle, coils and locker
4.88 gears
2JZ-GE+turbo+intercooler
Re: tailgate window motor the same as door motor? [Re: Greg_Canada] #853100 12/17/07 11:45 PM
I found your post helpful. Thanks. I just have to make some time to get to the junkyard. The motor I have is definitlly gone. I tested it strait to a fully charged battery. It barely moves and you can actually feel it grinding internally.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6332 MB (Peak: 0.7418 MB) Data Comp: Off Server Time: 2026-06-17 11:30:03 UTC
