4.3 TB Swapped #853421 12/16/07 10:47 PM
rodeorat Offline OP
Well we finally got the TB and IM swapped on the 3.1. I got a wiring pigtail with the GM style plug for the TPS from Oreily's. The plug didn't fit worth a crap. Bending one of the prongs. So we got it connected best we could just to see how it would run. ( I have another plug on the way to fix it right). We spliced black to black, blue to blue, and green to grey. Also readings were checked with an ohm meter.
Now we got it started after several attempts, but it is running very rich. Really loading up with fuel.I understand it takes the ecm a while to get sorted out. So I guess my questions at this point is...how well should it run on initial startup? and how long till the ecm gets up to speed. My TPS is non adjustable. But we drilled out the tb so we can adjust base idle. I would like to hear how the conversion went for others and what if any issues they had to deal with. Thanks.
GOD Said It, I Believe It, That Settles It.
Re: 4.3 TB Swapped [Re: rodeorat] #853422 12/20/07 05:54 PM
rodeorat Offline OP
UPDATE: Got the TPS connector fixed. Runs out pretty good. Doesn't idle well at all on cold startups. After a minute of feathering the gas it settles down and idles well. Hope this goes away as the ECM adjusts to the changes.
Re: 4.3 TB Swapped "Update" [Re: rodeorat] #853423 12/22/07 06:20 PM
rodeorat Offline OP
When we did the swap we were using the coolant temp sensor that was on the extra intake I bought. Swapped it out for the original. Now it cranks and runs like a top. Isn't a huge increase in power. Most noticable when pulling hills. Hardly have to mash on the gas at all now.
Re: 4.3 TB Swapped [Re: rodeorat] #853424 12/24/07 03:04 PM
F
Fujisawa_Rob Offline
I take it you are running the factory injectors? Did you get the intake bored to match the tb?
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: 4.3 TB Swapped [Re: Fujisawa_Rob] #853425 12/25/07 01:43 PM
rodeorat Offline OP
Right. Running the 3.1 injectors. Gave up on getting someone around here to bore the intake so I did it myself with a dremel. Turned out a lot better than I thought it would.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6072 MB (Peak: 0.6730 MB) Data Comp: Off Server Time: 2026-11-02 12:27:02 UTC
