22 RE Cylinder head -differences #853431 12/17/07 12:19 AM
Doc279 Offline OP
I have a 1985 $ runner with the 22RE engine. I've found a cylinder head that has round cylinder ports rather than the kidney shaped port. Is that the only difference ? Will this head work on my engine ? Tried searching and came up empty.
Thanks in advance for the responses
Just an OLD hippy with lot's of experience !
Re: 22 RE Cylinder head -differences [Re: Doc279] #853432 12/17/07 01:27 AM
CJM Offline
sounds like an earlier 82-84 22r head .. maybe even a 20r head ..
in any case .. deck heights on the blocks are different ... and head heights are also different .
It'll bolt on .. but it WONT work .
you'll need to find one from 85-95 .
83 Trekker SR5
NEW Trekker forum
Re: 22 RE Cylinder head -differences [Re: CJM] #853433 12/17/07 01:48 AM
Doc279 Offline OP
The price is right but I'll move on. Here is the link to the rebuilt 22RE head.
http://cgi.ebay.com/ebaymotors/Toyo...617QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Re: 22 RE Cylinder head -differences [Re: Doc279] #853434 12/17/07 02:30 AM
kewlynx Offline
Round exhaust would be 22R-- maybe RE on a Celica.
For your trivia folder:
20R22R History <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: 22 RE Cylinder head -differences [Re: kewlynx] #853435 12/17/07 02:46 AM
Doc279 Offline OP
VERY helpful - thank you sir ! The head listed has pear shaped exhaust ports with a round cylinder port - not kidney shaped. The seller is telling me that it will fit my 1985 22RE - I will pass and find the right application.
Re: 22 RE Cylinder head -differences [Re: Doc279] #853436 12/17/07 02:51 AM
kewlynx Offline
Yeah Doc, make sure of what you pick up. The timing chains between the pre and post '85 long blocks are different by 3 links, so you'd never get it set up right.
Re: 22 RE Cylinder head -differences [Re: Doc279] #853437 12/17/07 04:04 AM
yota4runna Offline
This head in the eBay listing is indeed the one you're looking for. It has the pear-shaped ports of the '85 - '94 engines. Look at the difference in the picture in the link Kewlynx gave you, repeated here:
http://www.babcox.com/editorial/ar/ar119838.htm
Re: 22 RE Cylinder head -differences [Re: yota4runna] #853438 12/17/07 04:54 AM
Doc279 Offline OP
I went back to E-bay to look at the head and somebody already bought it. Oh Well - I'll find one.
My head has been repaired but I beleive that there is still a problem - I am burning oil and smoking - white dark smoke. I believe that the shop did not pressure check the head - Compression is 165 lbs on all 4 cylinders. I posted about this earlier this month - problems after a head gasket install.
Thanks for the responses
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6275 MB (Peak: 0.7265 MB) Data Comp: Off Server Time: 2026-05-29 21:12:11 UTC
