22 RE Cylinder head -differences
#853431
12/17/07 12:19 AM
I have a 1985 $ runner with the 22RE engine. I've found a cylinder head that has round cylinder ports rather than the kidney shaped port. Is that the only difference ? Will this head work on my engine ? Tried searching and came up empty.
Thanks in advance for the responses
Just an OLD hippy with lot's of experience !
Re: 22 RE Cylinder head -differences
[Re: Doc279]
#853432
12/17/07 01:27 AM
sounds like an earlier 82-84 22r head .. maybe even a 20r head ..
in any case .. deck heights on the blocks are different ... and head heights are also different .
It'll bolt on .. but it WONT work .
you'll need to find one from 85-95 .
[Re: Doc279]
#853434
12/17/07 02:30 AM
Round exhaust would be 22R-- maybe RE on a Celica. For your trivia folder: 20R22R History <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: kewlynx]
#853435
12/17/07 02:46 AM
Round exhaust would be 22R-- maybe RE on a Celica. For your trivia folder: 20R22R History <img src="/forums/images/graemlins/kewl.gif" alt="" /> VERY helpful - thank you sir ! The head listed has pear shaped exhaust ports with a round cylinder port - not kidney shaped. The seller is telling me that it will fit my 1985 22RE - I will pass and find the right application.
[Re: Doc279]
#853436
12/17/07 02:51 AM
Yeah Doc, make sure of what you pick up. The timing chains between the pre and post '85 long blocks are different by 3 links, so you'd never get it set up right.
[Re: Doc279]
#853437
12/17/07 04:04 AM
This head in the eBay listing is indeed the one you're looking for. It has the pear-shaped ports of the '85 - '94 engines. Look at the difference in the picture in the link Kewlynx gave you, repeated here: http://www.babcox.com/editorial/ar/ar119838.htm
[Re: yota4runna]
#853438
12/17/07 04:54 AM
I went back to E-bay to look at the head and somebody already bought it. Oh Well - I'll find one.
My head has been repaired but I beleive that there is still a problem - I am burning oil and smoking - white dark smoke. I believe that the shop did not pressure check the head - Compression is 165 lbs on all 4 cylinders. I posted about this earlier this month - problems after a head gasket install.
Thanks for the responses
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6240 MB (Peak: 0.7230 MB) Data Comp: Off Server Time: 2026-05-30 00:15:26 UTCValid HTML 5 and Valid CSS
