Heater stop working #853535 12/17/07 03:39 PM
L
Locked_Solid_Toy Offline OP
For some reason last time i was back home driving my truck the heater just stoped working. It still blows air but it is the same temperature weather the slide is on cold or hot. I don't have ac if that makes any difference.
-Thanks for everything
1985 yota 22RJasper motor w/ cam,webber carb.Marlin histeer & 4"springs, AllPro jonny jointshackles. Bds yj springs upfront. Bilstein 5150's all around. 4.88 yukon gears,detroit locker and truetrac. Fj80 Master cylinder, 33" MTR's
Re: Heater stop working [Re: Locked_Solid_Toy] #853536 12/17/07 03:53 PM
engnbldr Offline
>>>*Three possible causes. Low coolant level, an obstruction of some kind like a hose or heater core plugged, or a heater control valve failure....*EB
*Beats the he** outa me!....*LOL**...
Re: Heater stop working [Re: Locked_Solid_Toy] #853537 12/17/07 05:01 PM
4Crawler Offline
Check the heater valve on the firewall, make sure the cable is still attached. Not uncommon for that to pop loose.
And any gurgling or whooshing sound from the dash area when you rev the engine?
Re: Heater stop working [Re: 4Crawler] #853538 12/18/07 03:19 PM
L
No i don't think so i will recheck, what does it mean if it is.
Re: Heater stop working [Re: Locked_Solid_Toy] #853539 12/18/07 04:01 PM
4Crawler Offline
Gurgling noises indicate some sort of bubbles going through the heater core, usually varies with engine revs (different flow rate). Could be due to low coolant, or air trapped in the cooling system or exhaust gas from the cylinders leaking past the head gasket.
Re: Heater stop working [Re: 4Crawler] #853540 12/22/07 09:24 PM
L
I am in Rancho Cordova, California, today and tomorrow would it be a good idea for me to pick up a Heater Control Valve From the auto dismantlers just in case thats the problem, How much are they and are they easy to install.
-Thanks
Re: Heater stop working [Re: Locked_Solid_Toy] #853541 12/23/07 12:39 AM
Adam F Offline
Easy to install. Its bolted to the top middle of the firewall in plain view. Has a cable hooked to it. Unhook the cable and move the control manually. Hoses on both sides should be hot. Shouldnt cost you but 10-20 at the most.
97 4R, stock, daily driver
Re: Heater stop working [Re: 4Crawler] #853542 12/24/07 06:42 AM
A
Anthony_89 Offline
the little plastic arm broke on mine.. we wire tied it back on:) still working.. that was my problem
Anthony
Re: Heater stop working [Re: Anthony_89] #853543 12/24/07 07:45 PM
L
No gurgling sound when i rev it, I topped of the coolant and it still doesn't blow hot air, it blows air just fine but its not hot air. I am going to check the hoses to see if that helps
Re: Heater stop working [Re: Locked_Solid_Toy] #853544 12/25/07 02:24 AM
kewlynx Offline
Sounds like your blower resistor went south; I take it your temp guage is still in operating range, yes?
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6397 MB (Peak: 0.7434 MB) Data Comp: Off Server Time: 2026-05-30 02:24:47 UTC
