Heater stop working
#853535
12/17/07 03:39 PM
For some reason last time i was back home driving my truck the heater just stoped working. It still blows air but it is the same temperature weather the slide is on cold or hot. I don't have ac if that makes any difference. -Thanks for everything
1985 yota 22RJasper motor w/ cam,webber carb.Marlin histeer & 4"springs, AllPro jonny jointshackles. Bds yj springs upfront. Bilstein 5150's all around. 4.88 yukon gears,detroit locker and truetrac. Fj80 Master cylinder, 33" MTR's
Re: Heater stop working
[Re: Locked_Solid_Toy]
#853536
12/17/07 03:53 PM
For some reason last time i was back home driving my truck the heater just stoped working. It still blows air but it is the same temperature weather the slide is on cold or hot. I don't have ac if that makes any difference. -Thanks for everything >>>*Three possible causes. Low coolant level, an obstruction of some kind like a hose or heater core plugged, or a heater control valve failure....*EB
*Beats the he** outa me!....*LOL**...
#853537
12/17/07 05:01 PM
Check the heater valve on the firewall, make sure the cable is still attached. Not uncommon for that to pop loose.
And any gurgling or whooshing sound from the dash area when you rev the engine?
[Re: 4Crawler]
#853538
12/18/07 03:19 PM
No i don't think so i will recheck, what does it mean if it is.
#853539
12/18/07 04:01 PM
Gurgling noises indicate some sort of bubbles going through the heater core, usually varies with engine revs (different flow rate). Could be due to low coolant, or air trapped in the cooling system or exhaust gas from the cylinders leaking past the head gasket.
[Re: 4Crawler]
#853540
12/22/07 09:24 PM
I am in Rancho Cordova, California, today and tomorrow would it be a good idea for me to pick up a Heater Control Valve From the auto dismantlers just in case thats the problem, How much are they and are they easy to install.
-Thanks
#853541
12/23/07 12:39 AM
Easy to install. Its bolted to the top middle of the firewall in plain view. Has a cable hooked to it. Unhook the cable and move the control manually. Hoses on both sides should be hot. Shouldnt cost you but 10-20 at the most.
[Re: 4Crawler]
#853542
12/24/07 06:42 AM
And any gurgling or whooshing sound from the dash area when you rev the engine? the little plastic arm broke on mine.. we wire tied it back on:) still working.. that was my problem Anthony
[Re: Anthony_89]
#853543
12/24/07 07:45 PM
No gurgling sound when i rev it, I topped of the coolant and it still doesn't blow hot air, it blows air just fine but its not hot air. I am going to check the hoses to see if that helps
#853544
12/25/07 02:24 AM
Sounds like your blower resistor went south; I take it your temp guage is still in operating range, yes?
