delayed starter reaction #853639 12/18/07 12:32 AM
chicomilo Offline OP
Hi and thanks in advance. I have an 88 22re truck that has been giving me problems. I seems to intensify when its cold. You can turn the key and hold it on and nothing happens for about 7 seconds. Then it fires up. In the cold sometimes it does not work at all. When you turn and hold the key there are some clicking noises. Wait and it will turn the starter and start the truck. Put in a new battery and it still does it. Starter does not drag when starting. Any help would be apprediated. Brian
Re: delayed starter reaction [Re: chicomilo] #853640 12/18/07 12:35 AM
4Crawler Offline
See below for a quick test you can do to isolate the source of the problem:
- http://www.4crawler.com/4x4/CheapTricks/Starter.shtml#EasyTest
Re: delayed starter reaction [Re: 4Crawler] #853641 12/19/07 05:52 PM
salvo Offline
Had the same problem... After reading rogers page i replaced the contacts and have had no troubles since... cheep fix contacts only cost about 8.00 and took about a hour of my time
Re: delayed starter reaction [Re: salvo] #853642 12/20/07 12:12 AM
I think I got it fixed. I cleaned some electrical connections on the starter and everything seems to be ok. Salvo what contacts are you refering to? Always helps to learn something! Brian
Re: delayed starter reaction [Re: chicomilo] #853643 12/20/07 01:57 AM
4Crawler Offline
The copper contacts inside the starter solenoid:
More info:
Re: delayed starter reaction [Re: chicomilo] #853644 12/20/07 02:41 AM
kewlynx Offline
Get familiar with our Yota section above.
http://www.4x4wire.com/toyota/maintenance/starter/
Welcome to the board!
**ubi apis- ibi salus**
Re: delayed starter reaction [Re: 4Crawler] #853645 12/26/07 03:32 PM
O
onepingCharlie Offline
Now if we could only find a way to replace the plunger ring !!!
OnepingCharlie
onepingonly@gmail.com [color:"red"] [/color]
Re: delayed starter reaction [Re: onepingCharlie] #853646 12/26/07 06:38 PM
DRTDEVL Offline
There are "starter rebuild kits" out there... I found one for about $25 a few year back at an automotive electrical shop in Florida.
Contained contacts, insulating rings, and a new plunger.
I should have bought it. <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: delayed starter reaction [Re: DRTDEVL] #853647 12/27/07 01:14 AM
W
Whizkidder Offline
I recently got one on Ebay -- included contacts, insulating rings, and a new plunger. Just search for "clicker fixer" on Ebay Motors.
Good luck.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6298 MB (Peak: 0.7325 MB) Data Comp: Off Server Time: 2026-06-17 06:48:29 UTC
