What next?? #853680 12/18/07 03:52 AM
damitboy Offline OP
Well, I am attempting to breath some life back into a 94 XJ. I bought it recently with 126,000 miles. It runs and drives great but there are a couple issues. I, of course, changed all fluids, put on new tires, checked plugs/wires/cap, changed all hoses, new air filter, new heater control valve, new fan clutch, new fuel filter, cleaned carb, oiled all hinges locks, etc. The two problems I need to look at are the engine sounds loud when warmed up like clacking lifters. It sounds tight and quiet when cold. Normal?? Can the valves be adjusted on the 2.5? Thicker oil? The other problem was when cruising a dirt road in four wheel high in second gear I heard and felt a hard "kunk" "kunk" sound from the trans case?? I'm most concerned with the first problem right now as I can go without four wheel for a while. I want to make this Jeep my daily so I want it in good working order. Thanks for any help. D.
94 XJ 2 Door/2.5/5 SPD/4 WD
Re: What next?? [Re: damitboy] #853681 12/18/07 04:17 AM
BigJim Offline
The valve adjustment is a slightly LONGER pushrod...the dealer will have them and know the correct length to sell you.
A "klunk" could be a loose or broken tranny mount.. Prolly not inside the transfer case.
Re: What next?? [Re: BigJim] #853682 12/18/07 03:04 PM
damitboy Offline OP
Are the noisy rocker arms normal for this motor with this amount of miles? Should I not worry about it? On the Kunk sound, it definately felt like when a chain slips on a sprocket. Thats the best way to describe it. It happened when I put more load on it too.
Re: What next?? [Re: damitboy] #853683 12/18/07 05:07 PM
BigJim Offline
There are a few things that might make such a clunk.. Of course the springs, shackles and u-joints must be checked also. But the chain inside the transfer case slipping in such a way is a thing I have never heard of.. not like that anyway.
Re: What next?? [Re: BigJim] #853684 12/18/07 08:20 PM
damitboy Offline OP
What should I look for on the springs shackles and U-joints. I did grab the rear drive shaft, yanked and rotated it and it felt tight. The front had a degree or two of rotation but very slight. How do you tell if a U-joint or shackle or spring is bad? Also, does the noisy rockers sound normal for 126,000 miles? Thanks alot. D.
Re: What next?? [Re: damitboy] #853685 12/20/07 11:36 PM
damitboy Offline OP
Anyone?
I'd like to try to make some headway this weekend. My knowledge is pretty weak on 4wds so any help is greatly appreciated. Thanks. Dave
Re: What next?? [Re: BigJim] #853686 12/21/07 12:44 AM
Brown81CJ5 Offline
That's what I would be checking.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: What next?? [Re: Brown81CJ5] #853687 12/23/07 09:32 PM
damitboy Offline OP
Ok, I used the lug wrench to pry between the cross member and the mount and I was able to lift the tranny 1/4-3/8 of an inch. It "looks" ok but but how do you know for sure if the mount is bad? Should it not lift at all or is a little ok?
Re: What next?? [Re: damitboy] #853688 12/23/07 10:48 PM
BigJim Offline
hmmm I've never used a pry bar. I always use a jack.. 3/6 is too much.. It should be too tight to move by hand.
Re: What next?? [Re: BigJim] #853689 12/24/07 07:40 PM
Brown81CJ5 Offline
Yeah. I'll bet that if you look at the mount, it will look dry rotted and crumbly. Time to go to urethane.
Gun it and run it!
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6379 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-06-17 11:40:02 UTC
