Engine Swap #853918 12/19/07 03:54 AM
spoonie Offline OP
Hey....Just wanted to know if anybody had any ideas on what would be a good motor swap for me. I have a 1994 Toyota Pick-up 4x4 with a stock 4cyl. engine in it and a 4in body lift and 32 11.50 15's on it. Thanks for the help.
Re: Engine Swap [Re: spoonie] #853919 12/19/07 04:47 AM
kewlynx Offline
You want a drop-in or a project? What are your goals with the truck?
If you simply think your 22RE is gutless, you might consider regearing, given the size tire you're turning.
Depends on how deep your pockets are, and how much time you have for this.
**ubi apis- ibi salus**
Re: Engine Swap [Re: kewlynx] #853920 12/19/07 06:30 AM
spoonie Offline OP
I want to do it for more off-road purposes. It's mostly a winter truck. I have another vehicle I drive in the summer.
I don't want to go much bigger with like the lift or tires. Maybe just a small suspension lift and slightly bigger tires.
I rather get more power out of it. Because like small hills on street that come up i have to drop it to second or sometimes frist.
It will probably end up being a project, becuase i'll probably have to rebuild or get a better tranny.
Re: Engine Swap [Re: spoonie] #853921 12/19/07 07:11 AM
kewlynx Offline
Okay, again with the tires you're running, REGEAR; it's the best bang for yer buck at this point. Trust us. These other guys will chime in; give 'em a chance. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Also, consider doing a compression check to see how your engine is doing; magic numbers are 142-171psi, +/- 4%
Re: Engine Swap [Re: kewlynx] #853922 12/19/07 07:40 AM
F
flyinhawaiian Offline
Hey kewl, so what size gears would you recommend for his set-up? just curious. I have about the same setup and would also like to improve my perf. thanks.
Re: Engine Swap [Re: spoonie] #853923 12/19/07 09:49 AM
Snowtoy Offline
As what kewlynx stated, a gear change is your best bang for the buck. With 32's and 4.10's you have suffered a 15% power loss(assuming manual tranny), regearing to 4.88's will result in a 45 power gain over 6the stock set-up i.e, 4.10's andd 28's. You can pick up oem 4.88 3rd members for under $250 ea. However if you are considering running 33-35's in the future you should consider getting 5.29's now. The 5.29's will be a bit high w/32's and youwill run in the upper rpms on the highway, but you will have a better crawl ration on the trail. You could regear w/5.29s and a rear ARB for under $2k. An enginne swap alone will run you more than twice that amount and you still wont have the right gears for the tore size you are running.
If after you have regeared and still want more power you can rebuild the 22re, and get about 145 useable hp out of it by enlarging the cyl.s, head work(karger valves), a different cam, exhaust work, etc. This rebuild should still be about $2k(if you do the tear down/rebuild) which when added to the cost of the regear/locker would still be cheaper than swaping in a 4.3 Vortec, or a 2.7 Taco 4cyl.
Re: Engine Swap [Re: flyinhawaiian] #853924 12/19/07 09:53 AM
Snowtoy Offline
If not planning on running any tires larger than 32's, 4.88's would be the right set of gears. The 4.56 gears is the oem size for 31's and a 5-spd, though w/32's and a 4cyl. the 4.88's would be a better option.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6148 MB (Peak: 0.7098 MB) Data Comp: Off Server Time: 2026-06-21 12:16:20 UTC
