Auto to Manual hubs #854266 12/20/07 08:20 PM
MadGary Offline OP
My 1990 LWB LS montero has auto hubs. They need replacing. Can I buy a set of Superwinch Manual hubs and put em in? My Jeep has Manual, and I like em a lot better than auto.
Re: Auto to Manual hubs [Re: MadGary] #854267 12/20/07 08:34 PM
CapnCrunch Offline
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Auto to Manual hubs [Re: CapnCrunch] #854268 12/20/07 08:54 PM
Yup, easily done... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Auto to Manual hubs [Re: rxinhed] #854269 12/20/07 08:59 PM
MadGary Offline OP
Awesome, thx a ton! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Auto to Manual hubs [Re: MadGary] #854270 12/20/07 09:27 PM
hazy_daze Offline
When taking the old ones off, be careful with the allen head bolts, they strip easily. Also, don't over-tighten the small screws holding the outer portion of the manual hub on. Super easy to do, other than that <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Auto to Manual hubs [Re: hazy_daze] #854271 12/20/07 09:29 PM
sparkem Offline
I very highly suggest you put anti-seize on the allen screws.
Re: Auto to Manual hubs [Re: sparkem] #854272 12/21/07 04:17 AM
And hit them with Blaster the night before so they have a good soak before trying to take off. At least, that's what you'd want to do up here is the rust belt... <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: Auto to Manual hubs [Re: MontyMcV] #854273 12/21/07 04:35 AM
sparkem Offline
I am talking about the screws that hold the face of the hub on. I dont like them. Yes it would be a good idea to hit the bigger hub bolts with PB before taking them off. Make sure you use the correct size bit. I cant rmemeber what size, 8mm I think? Make sure the bit is seated all the way and apply torque slowly and evenly. It is a pretty easy job.
Re: Auto to Manual hubs [Re: sparkem] #854274 12/21/07 05:05 AM
hazy_daze Offline
8mm sounds right.
Re: Auto to Manual hubs [Re: sparkem] #854275 12/21/07 05:24 AM
Ah, right Sparkem. Even so, I'd hit the little ones too. They'd break faster if stuck on with rust.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6400 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-06-07 04:39:43 UTC
