i need to change my water pump #854449 12/22/07 08:39 PM
captainpants Offline OP
I know there's a ton of info somewhere on this site about replacing a water pump on a 94 3.2 rodeo but I can't find it using the search mode. Can someone direct me to that info. One other question pertains to brand of replacement. Any faves amoung the crowd? Any to stay away from?
Thanks for your help.
the Captain.
Re: i need to change my water pump [Re: captainpants] #854450 12/22/07 11:00 PM
boritz Offline
Don't know if it will help you in the USA, but the pump I purchased in Oz was: GMB WP3112 Water Pump and Gasket (made in Japan).
I can help with the procedure - I assume that you will also be replacing the timing-belt and it's components while you're doing the water pump? Either way the procedure is the same. Someone posted a copy of my 3.2V6 SOHC procedure PDF at
http://www.datazap.net/sites/Austra...u_V6_Timing_Belt_and_Water_Pump_rev2.pdf
The original is at http://forum.australia4wd.com/lofiversion/index.php?t7463.html
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
Re: i need to change my water pump [Re: captainpants] #854451 12/23/07 03:59 AM
BigSwede Offline
IF you are even close to due, this is an EXCELLENT time to change the timing belt and also the tensioner, since you're going to have everything off the front of the engine anyway.
Serenity now!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5930 MB (Peak: 0.6467 MB) Data Comp: Off Server Time: 2026-05-29 22:32:13 UTC
